high logged load?
Old Oct 2, 2007 | 05:20 PM
merkzu's Avatar
high logged load?
My load seems to be showing way too high, I'm on the stock 9 turbo at 27psi and it's showing upwards of 350?
http://spreadsheets.google.com/pub?k...8qSrU2D6z2zldA
Any ideas? Not sure whats wrong. The log is from evoscan. I checked my 2-byte settings in ecuflash and they seem to be right - and calculated load seems to be right up there with it anyways?
Old Oct 2, 2007 | 05:25 PM
JohnBradley's Avatar
e85 is a heckofa drug.
Although I can only reference Lucas' car (Englishracing) that I have seen logs up close and personal, your load isnt too far off from his for the same boost.
Old Oct 2, 2007 | 05:32 PM
Pd1's Avatar
Pd1
I agree with John, but would also guess that you're actually spiking to around 29psi, assuming that you're using a stock-ish intake setup. Heavily modified intake setups can result in load values that differ from those with stock intakes even though both can be moving the same amount of air.
Old Oct 2, 2007 | 05:34 PM
merkzu's Avatar
wow ok, thanks
Old Oct 2, 2007 | 05:36 PM
merkzu's Avatar
It's a BR Cone/maf pipe intake, I log boost with a map sensor on my zeitronix so I'm pretty sure its right
Old Oct 2, 2007 | 06:09 PM
https://www.evolutionm.net/forums/sh...light=E85+dyno
Old Oct 2, 2007 | 06:49 PM
merkzu's Avatar
sweet thanks
