Help with Knocking at 7000RPM
Old Oct 9, 2007 | 02:45 PM
Dosagex's Avatar
Alright i currently have a street tune that i copied from another evo owner.
I'm running 19psi which is what it was tuned for. when i run evoscan i have one knock here and there but when i redline it right at 7000 i get like 7 knocks pretty consistantly. So i was wondering what can i change, whether it be in the fuel map or timing? or something else? I'm also running 91oct in cali. I provided pictures of my fuel map and ignition map. What other info do i need to offer?
Street tune Fuel map
for comparison
Stock Fuel map
Street tune Ign map
for comparison
Stock IGN map
Notice timing wasn't changed...hmm
Thanks.
Old Oct 9, 2007 | 03:00 PM
Ph3n1x's Avatar
I see nothing different with your ignition maps? Hence whoever tuned you, didn't really tune you. If tuning is sex they just touched your *******.
It seems your running too much timing with too lean AFR on 91. No one cannot be sure without a DATALOG though.
Old Oct 9, 2007 | 03:02 PM
Mr. Evo IX's Avatar
Please post logs if you'd like help.
Old Oct 9, 2007 | 03:04 PM
RazorLab's Avatar
Probably too much timing up top if you are running more than stock boost. What are your mods?
Old Oct 9, 2007 | 03:10 PM
Dosagex's Avatar
tbe, licp. what should i change on the timing?
Old Oct 9, 2007 | 03:30 PM
Ralph's Avatar
How does the MIVEC look? Is it stock? You will be hard pressed to get away with 15 degrees advance top-end on 91 octane.. unless you're filthy rich.
2cents.
Old Oct 9, 2007 | 05:27 PM
ExViTermini's Avatar
Its really not much help w/out a log or at least a look at your other two ignition maps....
Old Oct 9, 2007 | 06:38 PM
Evo_Jay's Avatar
+1
Old Oct 9, 2007 | 07:13 PM
nothere's Avatar
try dropping the 180, 200 load cells down to 12 or so and 8 @ 220 at 7000rpm
maybe a degree less at 7500 etc.
I don't have any experience with IX but lowering the timing is the most immediate step until you know what the afr is.
if it helps you can try to back it up some.
Old Oct 9, 2007 | 07:20 PM
596736's Avatar
What are you logging with? What is you knocksum? The 2 ignition maps are identical
Old Oct 9, 2007 | 07:50 PM
RoadSpike's Avatar
Might just be a bit lean for the timing add a point of fuel at the top.
Old Oct 9, 2007 | 10:42 PM
codgi's Avatar
Post the logs and the mivec map. Ignition looks the same, fuel map looks a bit leaner than stock in a few places. A log with a wideband would probably be most useful.
Old Oct 9, 2007 | 10:50 PM
JohnBradley's Avatar
Fuel map at 7000 since his lean spool is still on would put AFR's at 11.5 +/- .1 with normal mods.
I doubt the MIVEC will make the knock at 7K, but never know.
Lucas English's Avatar
Well map 1 on a IX is cold running map which looks stock and most tuners don't mess with it to much. We need to see timing maps 2 and 3 to know what is going on.
Old Oct 9, 2007 | 10:53 PM
alan678's Avatar
Try changing the lean spool feature to shut off at 8k rpms - The stock value is 7k rpms (reason for 8k is that you will never get out of lean spool since you wont rev that high...i hope) It could be the jump from lean spool turning off in conjunction with the fuel mapping in that area that is causing it to knock right at 7k as you describe it...
Also why are your 280-300 load cells leaner than the 220-260 load cells? This could be bad if you ever over boosted....
