Can anyone help plz..
Old Oct 11, 2007 | 08:51 PM
staatz's Avatar
i had 1.32..just installed 1.29a..tried opening the unlocker first before using ecuflash and it wont let me pick up my rom. I just keep getting this..
[00:02:34.872] Version 1.29.906
[00:02:34.872] 8 memory models read.
[00:02:38.377] 140 ROM metadata models read.
[00:02:38.377] checksum module "subarudbw" loaded.
[00:02:38.377] flashing tool "wrx02" loaded.
[00:02:38.377] flashing tool "wrx04" loaded.
[00:02:38.377] flashing tool "sti04" loaded.
[00:02:38.377] flashing tool "sti05" loaded.
[00:02:38.377] flashing tool "mitsukernel" loaded.
[00:02:38.377] flashing tool "mitsukernelocp" loaded.
[00:02:38.377] flashing tool "mitsubootloader" loaded.
[00:02:52.568] sending init sequence 1 (0001)
[00:02:55.832] sending init sequence 1 (0003)
[00:02:59.087] sending init sequence 1 (FFFF)
[00:03:02.342] sending init sequence 1 (F0F0)
[00:03:05.076] no response to any known code
Can anyone help?
Old Oct 11, 2007 | 09:00 PM
JohnBradley's Avatar
Quick rundown:
ECU Unlocker for 1.28 was up and running?
Key was turned to start with car off?
ECUflash was opened after the car had been linked and the key turned on?
Old Oct 11, 2007 | 09:02 PM
bigric09's Avatar
what i have found with the unlocker is that it doesnt do much but enable you to get your immobilizer code from the ecu so you can rebuild the map.... so maybe that is working, and you are just expecting more ?
Old Oct 11, 2007 | 09:05 PM
staatz's Avatar
I just want to pull my rom so I can do the NLTS patch, but my car hates me and won't let me read it. And it was connected before I opened Ecuflash.
Old Oct 11, 2007 | 09:10 PM
bigric09's Avatar
you probably need to go thru, remove 1.29 and make sure 1.31/2 or whatever is off of your computer.... all folders are gone, and all registry entries are deleted. Those you will have to do manually. Then go back and install 1.29a and try again... that should work.
Old Oct 11, 2007 | 09:16 PM
staatz's Avatar
I went through and deleted ecuflash, and the openecu folder, but I dont know what else I should delete...
Old Oct 11, 2007 | 09:22 PM
recompile's Avatar
Are you sure you're turning the key all the way to ON (past Accessory), and you're doing so RIGHT before trying to read with EcuFlash ?
Old Oct 11, 2007 | 09:25 PM
staatz's Avatar
Yep, I dont turn it to the ON position until after I choose read ecu and select my choice.
Old Oct 11, 2007 | 09:26 PM
Okay thats too late, but not necessarily the problem.
Old Oct 11, 2007 | 09:30 PM
staatz's Avatar
I'll go back out and try it again, but yet its 12:30am and this is still bothering me.
Old Oct 11, 2007 | 09:38 PM
staatz's Avatar
Well, tried again and got the same code...hates me.
Old Oct 11, 2007 | 09:47 PM
ohhgyeahfasho's Avatar
i had this problem and my friends did as well when i was tuning their cars. i have found a solution and i know the cause of this.
Cause: LOW BATTERY.
when your tuning the fix is this..follow this steps..
The Fix:
1. Turn off all the lights inside the car, turn off radio, basically all electronic gadgets.
2. Turn ur engine on, and drive around your block for at least 5min.
3. Turn engine off, hook on the Tactrix Cable and flash your ecu.
this worked on every single one of my friends cars, and mines as well. so i believe this will fix your problem. good luck.
Old Oct 12, 2007 | 05:13 AM
staatz's Avatar
Thanks ohhgyeah, I'll try this after class and post up how it goes.
Old Oct 12, 2007 | 08:10 AM
no problem. just make sure you drive around for a lil while, it will give ur battery time to recharge..and then go straight home and hook up ur tactrix cable and then have fun tuning your car.. let me know what happens..
Old Oct 12, 2007 | 08:48 AM
staatz's Avatar
Well, didn't get too far..haha Drove around, made sure everything was off and still got the same error. Did it with another car on another laptop and different version of ecuflash and same thing. The tactrix cable is brand new. Is it supposed to say anything in the bottom right hand corner of ecuflash, becuase all mine says is Serial Port 1.3 Universal 9*24r or whatever. Should it say mitsubishi when connecting it to the car?
