Engine cold map /// Emissions /// ???
Old Oct 24, 2007 | 06:53 PM
ExViTermini's Avatar
I thought you guys ran all 3 hi-octane maps with the same values?
Old Oct 24, 2007 | 09:04 PM
Jeff_Jeske's Avatar
Originally Posted by tephra
as far as I can tell the 1,2,3 map deal is this:
when mivec is advancing (ie the same or bigger than last time) interpolate between 1 & 2
when mivec is retarding (ie smaller than last time) interpolate between 2 & 3
my car sux when its cold too
Grrrrrr...... I was under the impression that #3 was a safety map. Maybe I shoudl think about making 1,2, and 3 identical.
Old Oct 24, 2007 | 09:13 PM
tephra's Avatar
nope - i've done some logs and all 3 maps get used fairly regularily.
either:
1) make the same changes to all three maps
2) make changes to #2 only as this is a common map that the ECU uses in making any timing calculation (when NOT in error condition)
3) make all 3 maps the same..
each has their own merits, none is more right or wrong.
Although you have to wonder why there are 3 maps in the first place... Mitsu must have some inside info we dont know yet :P
