New cams, tweak what?
Old Oct 26, 2007 | 12:35 PM
BoostEEd's Avatar
Hey guys. I had the following setup:
3" TBE
Intake
walbro 255
I have it dialed in pretty well now. I just installed the LICP, UICP, 3.5" IC and 272/272 cams and haven't fired it up yet. Going to this weekend. I was wondering if you couldn't help me out a bit.
Before I take it out and do some pulls to street tune it is there anything I should be aware of, or anything I should tweak BEFORE running it? I can watch the AFRs and EGTs no problem, but I'd rather start safe.
Are my maps I hve now going to be a good starting point or should I richen it up and pull some timing before I do my first pull? Should I try and get the idle dialed in before worrying about anything else or will that have little to no effect on my WOT tuning?
Thanks
Old Oct 26, 2007 | 12:58 PM
cpoevo's Avatar
I always start at idle and cruising speeds before I move to WOT. I also lower the boost and slowly start raising it. I usually raise the boost about 1.5-2.0 psi when I make adjustments.
