AFR Too High? Newbie still learning
Old Nov 12, 2007 | 09:43 AM
rish197's Avatar
Hi Guys,
So I have been trying to get the AFRs down to a decent level. How do these look? I have trying to get to about 11.7:1. I still need to fix the spool up areas, but I am just trying to see where I stand. I should also mention I live in Orlando, running on 93 gas and about 22psi.
Thanks for helping!!!
Jason
Old Nov 12, 2007 | 09:45 AM
bigric09's Avatar
id say that is a little lean, to be on the safe side id go with something closer to 11.5 to 11.3 by redline
Old Nov 12, 2007 | 12:53 PM
l2r99gst's Avatar
Your AFR is fine. Some people like a little leaner and some a little richer. As long as you tune for that specific AFR, you'll be fine. You'll get the feel for what is too rich or too lean for your particular setup and octane when it starts to knock too much or you can barely run any timing, etc.
Eric
Old Nov 12, 2007 | 02:33 PM
Asmodeus6's Avatar
I agree, but I think you could do more with timing than running it that lean. (typically)
