Evoscan2.0 is out
Old Nov 20, 2007 | 02:15 PM
RazorLab's Avatar
Just messed around with it. Very nice, like logworks:
FuelMap Vs. 2byte load:
FuelMap Vs. Wideband AFR:
FuelMap Vs. WGDC:
TimingMap Vs. 2byte Load:
TimingMap Vs. Knock:
Old Nov 20, 2007 | 02:28 PM
merkzu's Avatar
I'd think it should use the column the load is closest to? It put 51.3 in the 60 load column instead of the 50 load column. I know why, its just using greater/less than - but should it be that way?
Old Nov 20, 2007 | 02:36 PM
Asmodeus6's Avatar
Originally Posted by Mike01gsr
I was wondering that also, but by the looks of it I would say we still have to pay 10 bucks which means we pay 35 total.
Butt secks
w/e its worth it.
Old Nov 20, 2007 | 02:51 PM
kreionic's Avatar
I havent had a chance to look at the final release version yet. I was testing the betas and The last beta I got I couldnt see my last 2 rows of the timing map with MT. I was wondering if it got fixed or people are having a slight resolution issue?
Old Nov 20, 2007 | 03:04 PM
RazorLab's Avatar
Looks fine to me, see my screenshots above.
Old Nov 20, 2007 | 03:06 PM
Dapper Dan's Avatar
damn i didnt get the email yet can someone post up the link?
Old Nov 20, 2007 | 03:08 PM
Jack_of_Trades's Avatar
http://www.limitless.co.nz/evoscan/M...tx=05EC8A01E98
map tracer link
Old Nov 20, 2007 | 03:15 PM
Dapper Dan's Avatar
thanks
Old Nov 20, 2007 | 03:19 PM
dudical26's Avatar
razorlab - How do you switch between viewing fuel map and timing map?
Have you been able to load a ROM with re scaled AXIS or a definition file that has been changed.
I can' tell if its the modified ROM definition or the ROM itself but I can't seem to load my ROM with Tephra's knock patch into the maptracer.
Old Nov 20, 2007 | 03:34 PM
dudical26's Avatar
Has anyone else noticed that you CAN NOT select a port for a wideband AFR
Old Nov 20, 2007 | 04:11 PM
To switch between the IGN and fuel maps just right click the bottom map. I have my load rescaled to 300 and when I loaded my ROM ID from ecuflash it shows a max of 300.
I haven't hooked mine up to the car but it shows COM port 3 in the dropdown list and I could select it.
Old Nov 20, 2007 | 04:20 PM
RazorLab's Avatar
Right click on the map to switch between fuel/timing
The screenshots above shows a modded rom and rescaled as well.
Old Nov 20, 2007 | 04:39 PM
dudical26's Avatar
I had to mess around with my def a bit but I got it working. Thanks for the help.
Although, I'm still unable to get the port selection tab on wideband to open up.
I also noticed a bug - if you have the map tracer open, and you hit alt+tab to switch windows, when you switch back the data in the bottom part of the map tracer has changed and no longer reflects the data in the map. You have to right click and select the map again to get the proper data back.
- It would be awesome if you could actually adjust the values in the map as they are shown on the bottom section of the map tracer.
Old Nov 20, 2007 | 05:27 PM
Evo_Jay's Avatar
FuelMap Vs. WGDC:
Thats what I though, just like log works. But too bad it doesnt highlight the actual cells on your ROM table.
You even though the values are in the correct cells on the above template is a very good resource, I believe the real version of a map tracer would just high light the cells on your ROM, not on a template.
It does make ever thing a lot easier though.
Old Nov 20, 2007 | 05:33 PM
Evo_Jay's Avatar
Also, razor why do you have your load scaled up to 340? I thought the ECU didnt read more then 320 load?
