Evoscan2.0 is out
Old Nov 20, 2007 | 05:35 PM
  #31
Evo_Jay's Avatar
Originally Posted by dudical26
Has anyone else noticed that you CAN NOT select a port for a wideband AFR
I just noticed that. I wonder if it auto selects (i doubt it). Ill talk to hamish tonight.
Old Nov 20, 2007 | 05:37 PM
  #32
Evo_Jay's Avatar
I had to mess around with my def a bit but I got it working. Thanks for the help.
Although, I'm still unable to get the port selection tab on wideband to open up.
I also noticed a bug - if you have the map tracer open, and you hit alt+tab to switch windows, when you switch back the data in the bottom part of the map tracer has changed and no longer reflects the data in the map. You have to right click and select the map again to get the proper data back.
- It would be awesome if you could actually adjust the values in the map as they are shown on the bottom section of the map tracer.
That would be great, but then it would need a ecuflash plug in or something.
Old Nov 20, 2007 | 05:46 PM
  #33
dudical26's Avatar
Not necessarily. You dont need to be able to flash with it, just if you could change that values.
Old Nov 20, 2007 | 06:38 PM
  #34
Jack_of_Trades's Avatar
Originally Posted by in Evoscan Map Tracer Link by: Hamish
In a future version of EvoScan the bottom grid with the ROM data will be made directly editable.
He's working on that apparently
Old Nov 20, 2007 | 06:56 PM
  #35
Jorge T's Avatar
I have options for com 1, 3, 4 and 9, wideband on MTS on com9 but does not work. Same crap, hangs up and crashes.
I'm going to try with out the usb adapter and connect to com1(old school serial).
Old Nov 20, 2007 | 09:28 PM
  #36
fixem2's Avatar
I must be doing something wrong because the map tracer is not working for me. Will this only work with logs taken via 2.0 maptracer edition? I have to sets of logs from 2.0 only and do not get anything on the tracer. When I use the ROMID XML and my HEX file and check timing advanced I get 60 in the load 10 cell in the top left corner. ANy thoughts?
Old Nov 20, 2007 | 09:35 PM
  #37
My 1.0 logs work so its just something you are doing a bit funky I suppose.
Old Nov 20, 2007 | 09:59 PM
  #38
fixem2's Avatar
I find it interesting that the sample logs in the program work great, but none of my logs 1.0 and up work. Anyone have any thoughts?
Old Nov 20, 2007 | 11:16 PM
  #39
codgi's Avatar
Just downloaded...haven't installed it yet. Saved my old data.xml...is the new data.xml similiar to the old .99 version? I have a bunch of custom stuff I will have to move over to the new one I would imagine.
Anyone had any issues so far with using custom data.xml with v2.0?
Old Nov 21, 2007 | 12:15 AM
  #40
Evo_Jay's Avatar
Theres a feature to easily add new data items.
Old Nov 21, 2007 | 12:32 AM
  #41
codgi's Avatar
Thanks. I'll windiff it to 0.99 whenever I install it and see I guess. I prefer to deal with the xml straight up . So any other issues other than the non-selectable comport for wideband (holding off because of this I need my AFRs!!!)?
Old Nov 21, 2007 | 05:45 AM
  #42
evo4mad's Avatar
You can install the versions side by side.. there is no requirement to uninstall the previous version of EvoScan.
There was some new ComPort detection code I did for the wideband com port, i will change it back.
If your hex/xml file doesn't load in MapTracer, email it to me evoscan@limitless.co.nz and I'll check it out
yes, I am currently testing the editable cells in the rom file as mentioned above.
yes, great idea about highlighting the corresponding cells in the map tracer. (and I'll also check that the less than/greater than, and correct cells are being loaded. Let me know if you think its out by one cell.
I think I will apply an AFR data log conversion to 14.7AFR representation too.
Old Nov 21, 2007 | 07:08 AM
  #43
dudical26's Avatar
great!
What about the one other bug I noticed. When you use alt+tab to switch windows while the map tracer is open, all the data on the bottom portion is changed once you alt+tab back to that window.
Old Nov 24, 2007 | 10:30 AM
  #44
evo8426's Avatar
when i went out this morning to test out evoscan v2 i tried to log and for loadcalc it read out as -infinity and 2byte load read out as 35. can one of you guys tell me what is wrong?
Old Nov 24, 2007 | 01:10 PM
  #45
Evo_Jay's Avatar
Thats weird. Is your ROM modified to log 2byte load??
