more timeouts in EvoScan 2.0?
Old Nov 21, 2007 | 06:20 PM
Evol.ved's Avatar
I had the timeout problem but then it connected and stayed connected for a solid 15 minutes.
In any case it's a heck of a release. 2.0 is well worth the 10 dollars.
Old Nov 21, 2007 | 08:29 PM
evo8426's Avatar
anyone been able to keep v2.0 connected?
Old Nov 22, 2007 | 12:07 AM
nj1266's Avatar
Are you able to use the xml file from v0.99 in v2.0? I have my v0.99 xml file set up just the way I want it and would like to use it in the newer version.
Old Nov 22, 2007 | 08:13 AM
mrfred's Avatar
The formulas need updating. v0.99 was able to accept formulas with no multiplication symbol, e.g., "0.3125x". The new version requires multiplication symbols, i.e., "0.3125*x".
Old Nov 22, 2007 | 08:27 AM
trboboost91's Avatar
where do you go to download evoscan if you have lost it?
i paid the $25 and have a serial number but cant find where to download if ive already paid??? Lost my evoscan in a computer crash
Old Nov 22, 2007 | 08:38 AM
dawnduran's Avatar
write him an mail with your registered mail-account.
Old Nov 22, 2007 | 08:43 AM
Jorge T's Avatar
This answered my Q as well...tried logging fuel trims and used .99 formulas posted by nj and all were -24.8xxx I was WTF? I ended using mitsulogger then, now I know what was wrong.
Old Nov 22, 2007 | 10:06 AM
did that and he never responded!
Old Nov 22, 2007 | 10:55 AM
dudical26's Avatar
Originally Posted by turboracer
Dudical, did you plug your wideband in to the computer and try to select com port? I was only getting com 3 as well. Then I plugged everything in to the laptop. More comm selections appeared.
I'm getting a couple of time outs on start of logs as well.
Yes. It not even that there are no choice, its that there is not even a sub menu.
I click on select comm port and nothing happens, there is no menu with the possible ports to select.
Old Nov 22, 2007 | 10:56 AM
kreionic's Avatar
Its very easy to change the order now. You dont need to go through the xml to do so. Just right click on any item in evoscan. Theres an edit and move up or down. It takes longer if you use the move up so just click edit and then at the bottom theres a move up or down and its fast and simple. You can also edit or add any new entries in the edit section instead of going through the xml
