P0300
Old Nov 22, 2007 | 11:21 AM
raiceboi697's Avatar
Question P0300
does any one know why this damn things pops up? the dealership reflashed me and it went away, and when i started to tune my car it came back, does anyone know how to make this ****e stop?
Old Nov 22, 2007 | 12:58 PM
Ph3n1x's Avatar
What year is your car?
Email your Rom and i'll take a look at it.
Pm for email.
Old Nov 22, 2007 | 02:32 PM
JohnBradley's Avatar
Sorry for the brief threadjack but Lucas found a new P0300 fix for the 05's than basically does the same thing.
The ROM is labelled as a 96940013, but it can be defined as an 11 and it shows everything perfectly.
I have found with quite a few of the cars I do that some seem prone to the p0300 where others do not. Things to check include:
Idle timing is not really high
Coils arent ancient
Clutch/TOB isnt rattling
There seem to be quite a few different ideas as to specifically what sets it off but I honestly cant say because I havent had a problem with it. There might be some relation the ECU peripheries that I am using and how I have them set up. I am willing to take a look as well.
Old Nov 22, 2007 | 07:08 PM
he idol timing is high as that is the only was i could get my cosworths to idol right (12 degrees)
coils have been replaced
and the car dosent has a different style TOB ( tilton clutch) but the clutch does have the double disc rattle
if you could both send me or PM me a e mail address i can send you my maps
thanks
the evo comunity saves the day again
Old Nov 22, 2007 | 07:10 PM
bigric09's Avatar
lower your timing... raise your idle to about 1000 to 1100...
Old Nov 22, 2007 | 07:12 PM
the idol is already that high, i bumped it up a degree as a time until it idoled about right, now i just gotta tweak the AC maps so it idols right with that
Old Nov 22, 2007 | 09:53 PM
Well I would take those 13 & 10's out since the car actually doesnt idle there anyway. Evo's idle at about 25-30% so I would raise the line of 6's there to 8's max then go to the ISC table and in the 77 and 82* area where its now at like 22 and 20 steps bump them to 80 or so. A stock IX is 100 by comparison. I would try that and see if it "stays" fixed. If not I happen to have the even newer version of the P0300 fix (the 96940013) you could transfer everything over onto if you wanted. I really think that the P0300 is a side effect of being modified, like an error table we cant always see. I know of a few IX's that as soon a tuned map went on them they would kick out the CEL and put them back to stock and they were fine.
Old Nov 22, 2007 | 09:58 PM
if you could send that map ill try that as well as switch the other things u were talking about, thanks john
Old Nov 22, 2007 | 10:06 PM
Well unfortunately there isnt a finished xml for the type 13 yet. I am still working on making sure everything is the same. I associated it as an 11 in ECUflash and while it shows up and all I am comparing all the addresses between the 11 and 13. Start with that stuff I just mentioned though and see if helps get rid of the P0300.
Old Nov 23, 2007 | 08:36 AM
Ph3n1x's Avatar
Lower the Idle timing to no more than 7*
Old Nov 23, 2007 | 08:37 AM
if the timing is any lower the car stumbles at idol like its gonna die, i started to bump up the timing from the standard 5 one degree at a time untill it idoled right
Old Nov 23, 2007 | 08:47 AM
john as soon as i get out of bed and walk to my car im gonna try this, on the ISC tables i made the 77 and 80 areas on all three of them the same lets see if this helps
Old Nov 24, 2007 | 08:23 AM
well john it worked and idol idol vacume went down to a hair above 20 and held pretty rock steady, but once i turned the car off and started it back up its like the changes to the ICS didnt save cause the idol vacume went right back to 10....any ideas cause i dont feel like flashingmy car everytime i wanna drive her around
