EVOscan 2.0 maptracer issues
Old Nov 30, 2007 | 12:29 PM
Evo_Jay's Avatar
OK i didnt talk to hamish, but i realized you cant delete the ROMs that it comes with. If you do, the program refences the .msi file and puts them back. Yours probably didnt work cuz the program couldnt find the .msi file, which is in the .rar file. Regardless you should always use the ROM that your working on, cuz the load/rpm scaling could be changed from normal.
Also, changing all the def. file works, and i think its a good idea.
Old Dec 6, 2007 | 11:10 PM
Dapper Dan's Avatar
im having the same issue, i cant get maptracer to work.. it also wont read my lc1
Old Dec 7, 2007 | 09:52 AM
smartbomb's Avatar
Hamish knows about this so I assume he will get back to me when he figures it out. I'll let everyone know when I hear from him.
Old Dec 12, 2007 | 12:10 AM
Dapper_Dan's Avatar
bump
Old Dec 18, 2007 | 05:41 AM
broddey's Avatar
Updates?
Old Jan 8, 2008 | 01:13 PM
lapulapu's Avatar
anybody get this to work correctly without using the sample log files?
Old Jan 8, 2008 | 04:09 PM
lapulapu's Avatar
Solution: https://www.evolutionm.net/forums/sh...d.php?t=317437
Old Jan 19, 2008 | 06:22 AM
chmodlf's Avatar
The above solution does not work for 94170008 03 evo8. ARGGGGGGG!
Old Jan 19, 2008 | 06:33 AM
Evol.ved's Avatar
I had the same problem. I emailed him several times and sent him the proper information and never heard back about it.
Old Jan 19, 2008 | 09:11 AM
lapulapu's Avatar
modify your ecuflash rom directory to point at the xml rom directory in the evoscan ROM folder.
Old Jan 19, 2008 | 12:50 PM
chmodlf's Avatar
https://www.evolutionm.net/forums/sh...61&postcount=7
Old Jan 19, 2008 | 01:59 PM
Big~D's Avatar
I had the same problem. I found that logs recorded in v0.99 work fine when viewed in version 2 and also work on maptracer. So now I log with V0.99 and view with v2 maptracer.
PITA but it works.
Old Jan 19, 2008 | 07:54 PM
chmodlf's Avatar
PITA but it works.
That is one thing I didn't try. Thanks it works.
Old Jan 20, 2008 | 01:17 PM
Big~D's Avatar
I stumbled on it by accident as I noticed that logs I had made before upgrading to V2 worked in maptracer.
Old Jan 20, 2008 | 04:06 PM
chmodlf's Avatar
I got a reply to my email to evo4mad about the above issues. He said v 2.1 is coming with the maptracer tweaks.
