New log for review
Old Dec 29, 2007 | 08:43 PM
BCOZEVO's Avatar
New log for review
Other then being a little rich anyone see anything on this small log I should address?
thx
File Type: zip
Old Dec 29, 2007 | 08:50 PM
cpoevo's Avatar
Your injector duty cycle is too high from 5500 rpm and up. I would not go not go higher than 85%IDC. You need to lean it out first to the AFR you want to run then tune the timing. For a IX that looks like a lot of timing up top.
Old Dec 29, 2007 | 08:55 PM
recompile's Avatar
If you don't have an upgraded fuel pump, it will let you pull a lot of fuel and lower your IDCs. 10's are definitely too rich though... stay out of 10's completely.
Try a few clicks more timing at peak torque... you should be able to run 4-5 without an issue.
Old Dec 29, 2007 | 09:12 PM
BCOZEVO's Avatar
On the tuning primer i was reading "Setting your AFR depends to a large extent on the boost and timing that your car is running" so timing comes first right?
I have a Walbro 255, also I am fighting a MAFT Gen 2 so it a hand and hand type thing on the AFR's
thx for the input guys
Old Dec 30, 2007 | 10:58 AM
BCOZEVO's Avatar
Another log for the fire:
I was able to bring the timing back down in the high range and get the AFR's in the low to mid 11's now, but I am getting some knock during shifting.
log2 is a pull from 3rd
log3 is a pull from 3rd with shifts to 4th and 5th.
Any ideas?
Thx
File Type: zip
File Type: zip
