EcuFlash installation problem
Old Jan 16, 2008 | 02:01 AM
Malmoe_Sweden's Avatar
Having trouble installing ECU-flash 1.34...... gets this message all the time
Nsis error
The installer you are trying to use is corrupted or incomplete
This could be the result of a damaged disc,a failed download or a virus
You may want to contact the author of this installer to obtain a new copy
It may be possible to skip this check using the /NCRC command line switch
(NOT RECOMMENDED)
anyone with this problem?
Have tested it on 2 computers...still the same
// Lars
Old Jan 16, 2008 | 04:39 AM
rovanpera's Avatar
http://openecu.org/index.php?title=EcuFlash
try this, it worked for me (xp professional)
peter
Old Jan 16, 2008 | 07:57 AM
Still having problem with 1.34
I downloaded the file and managed to install it with /ncrc command
When I tried to start the program I got a error message saying that it wasnīt a valid win 32 program...
What could be wrong?
Old Jan 16, 2008 | 08:40 AM
MR. Tim's Avatar
I think i had a similar issue a while ago when i first installed ecuflash. I want to say that it is related to dot net framework. Make sure you have dot net framework version 2 or 3 or whatever they are up to now. I think this was my issue but it was a while ago so i cant remember exactly.
http://www.microsoft.com/downloads/d...displaylang=en
Old Jan 16, 2008 | 12:36 PM
problem solved
My problems are now solved.
Obviously I have had some disturbance on my wireless router.
I downloaded exact the same file several times and got error messages....but when I installed it from an email it worked fine....... strange isnīt it?
well well., I am up and running now....next step is to learn the program.
// Lars
