stumped with knock...please give input
Old Jan 18, 2008 | 04:39 PM
John F's Avatar
Here's my timing map. I can still get some knock on spool up (GSC S1 cams) so you could try this and maybe even reduce timing a little in 2500rpm 100 to 260 to see what happens.
Old Jan 18, 2008 | 06:49 PM
C6C6CH3vo's Avatar
I would pull timing until knock decreases, fix your wideband, and optimize the fuel
Old Jan 19, 2008 | 04:29 PM
pltek's Avatar
it looks like pretty agressive timing, start there, pull back
Old Jan 19, 2008 | 06:02 PM
Mad_SB's Avatar
Just for grins, pull your plugs and look at the piston tops with a bright flashlight, make sure they are all the same color. If ont is significantly lighter in color than the rest you may have a bad injector on that cylinder. One of my stock injectors went bad at about 20,000 miles.
Live4Redline
Jul 17, 2024 07:09 AM
Seancj
Jul 2, 2015 06:22 AM
Solarwater
27
Jul 16, 2013 05:48 PM
MyronGainz
Jun 5, 2013 05:10 PM
Raceghost
Sep 4, 2009 10:06 AM
