Spudder Problem Someone Help!
Old Feb 8, 2008 | 10:30 AM
mplspilot's Avatar
Originally Posted by tseitz123
Wait a second here! So, you're telling me that I'm hallucinating? I had the EXACT same issue as the OP and by changing nothing else besides those tables, the issue was resolved. I'm not gonna say that it makes ANY logical sense here, but the bottom friggin line is, the problem disappeared. Coincidence? Maybe.
I'm just saying you don't know what you're talking about is all. If it fixed the problem you must have changed something else. Like "Boost limit" value. Or "boost cut delay timer". Ring a bell? It's in the same "Turbo" section as the tables you talk about.
Old Feb 8, 2008 | 10:39 AM
evo_domination's Avatar
Originally Posted by rolly1818
Def check the gapping of the plugs, i think he just threw them in there and that is misfireing....gap them to .26, have him pull all 4 and recheck the gap before going any further. or adjusting the ecu
^^ definately check this
I couldn't agree more! I just had the exact same problem about three weeks ago. I went through trouble shooting all the bolt ons and easy stuff. After I had restored the stock settings on the ecu and put most of the stock parts back on I was ready to check the cams and realized I hadn't checked my plug gap. The plugs were my problem! Check the gap and heat range first! Start at the easiest and work your way up. It might save you some wrench time.
Old Feb 8, 2008 | 10:52 AM
2k4EvoVIII's Avatar
Thanks Guys! Well im trying to get ahold of him now to see what he can do. As far as mod the car has a o2 Housing, Exhaust, Obx Intake, some knock off Greddy BOV and everything else is stock. Still running ecu boost and everything.
Personally i would never install the parts he chose to install but he is one of those hmmm how to say this...half *** guys i guess you would say. The car was running fine and then got in a pretty bad accident. It was then towed and fixed. Ever since the very first time it fired back up it has had this problem.
I will have him check the plugs!
Chris
Old Feb 9, 2008 | 11:50 AM
Slo_crx1's Avatar
Chris
I'll bet a lot of the issue is with that knock-off bov. They're not the greatest at holding higher pressures and can leak pretty bad. In my experience tuning Honda's with these garbage parts on them they usually let go right around the 12-13psi range, so it's very possible that his valve is leaking pretty badly causing it to run extremely rich (which in turn would lead to the misfire code) and might account for the strange looking air volume log as well. IMHO, he should really put a stock DV back on, either the original plastic one or a metal 9 valve until everything's sorted out.
