JDM MAP sensor vs Zeitronix Boost
These are both calibrated for my altitude of ~2500ft. I did not think they would be this close. I guess I don't need my JDM sensor.
This is a huge difference in the vacuum area but boost looks almost the same. It was like this on all my logs tonight.
I assume you meant Evoscan and not ECUFlash lol. The only other way to datalog it in evoscan without splicing is to use the serial output with a USB adapter. You just need to plug it in and tell Evoscan which USB port its plugged into and you can datalog in evoscan without having to use the Zeitronix software. It lags a LOT sometimes, most of the time its just fine though.
