EGR patch request
Old Feb 11, 2008 | 05:58 AM
BarryC's Avatar
Originally Posted by cossie1
Barry in my Rom (which as you know is the same as yours)
my perephery is 56D0
my perephery 1 is 0009
my perephery 2 is 8A89
my perephery 3 is 0300
I have just connected pin 6 to 53 (so that the sas is working, as I was told this will help with the pops and bangs), but now getting the EGR cel, so need to disable this function too
yep thats what will happen,
you could try and fit a resistor to simulate the egr or if you use a boost controller swap the boost solenoid to pin 6 that will stop the fault code but I ended up getting a P0400 EGR flow fault code,
also my perephery's are
56D0
0008
8A88
0300
as I have lean spool disabled
according to bez's perephery calculator changing perephery 3 to 0100 should disable EGR on 9055001,
I would also like to have my SAS back
Old Feb 11, 2008 | 06:06 AM
cossie1's Avatar
Well looking on here, it says on the usdm change EFDF to EDDF in perphery 2
I've just checked through alot of roms, i've picked up on my travels around the web and all e7 roms seem to be 8889. 8A89 etc etc
But I have 1, thats showing as 88D9 (this is a modded rom file), so I am gonna go and try 8AD9 on my car and see if it does anything.
If not, will change it back and change 0300 - 0100 in perephery 3 and see if that does the job.
Will post back in a few mins.
p.s Why do you want SAS back ?
I only connected it as I was told it's needed to get the pops and bangs to work propperly, but doesn't seem any different so far
Old Feb 11, 2008 | 06:23 AM
BarryC's Avatar
Ah I Know SAS aint anything major would just like it back as I thought the spool up was a bit quicker when it was on maybe its just me ?????
Old Feb 11, 2008 | 06:40 AM
cossie1's Avatar
Just for your info mate
8D89 works for me on perephary 2
No more cel for egr, and no cels for anything else either.
As for the sas it does make a slight difference with the pops and bangs, not noticed any difference with the spooling times or agressiveness though.
So going by that, 8D88 should work for you too
Whats the deal with lean spool then ?
Old Feb 11, 2008 | 06:43 AM
BarryC's Avatar
good stuff Russ will try it later,
Lean spool switch it off its a pain in the *** when ya are trying to tune fuel maps,
as it leans everything out,
Old Feb 11, 2008 | 06:55 AM
cossie1's Avatar
Got nothing in my xml to turn it on or off.
Old Feb 11, 2008 | 07:08 AM
BarryC's Avatar
na you just turn it off in the perephery
set perephery 2 to 8A88
and perephery 1 to 0800
for lean spool only
Old Feb 11, 2008 | 09:35 AM
burgers22's Avatar
My lean spool start and stop addresses are:-
Start 1680
Stop 1684
Scaling is RPMStatlimit
This should enable you to change the RPM at which the lean spool operates. I've pushed my stop RPM to 7500 so the AFRs don't suddenly drop off. I've left lean spool on as it has an effect when you are in boost for a long time, richens it up a bit.
Periphery 3 is set to 8A89 on my JDM 7, I've got SAS, but no idea if I've got EGR, I would think not.
MB
Old Feb 11, 2008 | 09:42 AM
cossie1's Avatar
My perephery 2 was set as that, but it gave Egr fault code when I reconnected sas, so I changed it to 8D89 and it removed the EGR fault code.
perephery 3 on my rom is 0300, which is also an evo 7 rom (says edm but we know that it's JDM really).
Old Sep 10, 2009 | 08:59 AM
downshift411's Avatar
in my case i would need the EGR. Disabling it only makes it harder to pass emissions. in my evo 4 engine. i have sas connected to pin 6. im running jdm evo 8 RA rom. making an egr and evap sim would somehow work with what i need to get by then. switch it off if need be.
Old Sep 10, 2009 | 12:22 PM
todd6027's Avatar
evo4 /5/6 never had egr .
fostytou
359
Oct 23, 2025 09:54 AM
turbotaloon95
Aug 9, 2016 07:51 AM
kiggly
Mar 14, 2016 05:29 PM
rcheung
Jan 28, 2016 04:44 PM
fireroasted
Aug 31, 2013 09:52 AM
