how much timing increase
Old Feb 12, 2008 | 10:33 AM
tkklemann's Avatar
Originally Posted by mplspilot
Also it's impossible to reach 310 load on a viii stock turbo with a TBE at 24 psi.
I am stupid. nevermind.
Old Feb 12, 2008 | 04:22 PM
lemmonhead's Avatar
thanks for the response, I will decrease timing just a tad, after looking at my map, it looks like I cant smooth things out more, I think their might be to much a timing jump. thanks guys.
Old Feb 12, 2008 | 05:59 PM
Slo_crx1's Avatar
Keep in mind OP has a IX not VIII, when you make suggestions.
Ahh, you're right...I must have missed that, thought he had an 8.
Quote:
Originally Posted by Slo_crx1 View Post
It does get more aggressive towards redline, probably to try and make up for the drop in psi (usually goes from 19 peak to around 15 by redline). If you're able to hold a steady psi to redline you definitely want to dial the timing back a little bit.
Complete misconception.
And why is that? I've always read and found that the higher the rpm, the lower the engine's VE tends to be after reaching it's peak VE, not to mention efficiency of the turbo and heat production above the said VE. Yes, you will have more timing advance than peak torque range due to the rpm speed being great (dealing with the physical time it takes the coil discharge to reach the plug in relation to engine rpm, etc.), but it's already been established that the stock high octane timing numbers are pretty aggressive, and become even more so as higher load percentages are being hit and held. I only meant to dial the timing back a bit from the stock numbers if he's hitting a higher load percentage than he was in stock form for the higher rpm range.
HermaN
Jul 7, 2010 01:22 PM
rolly1818
Jan 21, 2010 08:34 AM
acamus
Oct 24, 2008 06:22 AM
kkarim
May 22, 2008 11:43 PM
Rob W.
Aug 23, 2006 12:11 PM
