evoscan 2.1 problems and fixes
Old Mar 31, 2008 | 05:13 PM
  #61
nonschlont's Avatar
ok I just changed the est. torque formula to the update and works! I just learned "the hard way" that the car needs to be on to register. lol but now Im still noticing that my fuel cons. is still Nan... I changed the UNIT value to mpg... is it supposed to be in caps? also thanks for the previous info! good to know
Old Mar 31, 2008 | 05:30 PM
  #62
kreionic's Avatar
Originally Posted by Jack_of_Trades
Are you running vista? Their stupid 'compatibility files" option is annoying since it shows the old datasettings file first. If it shows up correct in evoscan, its saved in the correct datasettings file.
Not sure if your still having this issue. I had to click compatibility files too. I downloaded service pack 1 for vista and it cleared up that issue. Now I can just right click the saved logs and it opens fine
Old Mar 31, 2008 | 05:55 PM
  #63
Jack_of_Trades's Avatar
Cool thanks, I'llDL SP1 soon.
Old Mar 31, 2008 | 05:58 PM
  #64
Wicked E's Avatar
So I used the formula posted about for the trims for accuracy in EvoScan and got NaN for feedback. I wasted a whole drive not knowing the trims weren't reading...
Anyone have something to help me with?
Cheers-
E
Old Mar 31, 2008 | 06:06 PM
  #65
You did something wrong,lol. Just be sure its exactly the same as I listed. What are your request ID's for each trim?
Old Mar 31, 2008 | 06:17 PM
  #66
Wicked E's Avatar
Wouldn't be the first time I did something wrong... I have it typed in EXACTLY as it's stated above...
Request ID's:
0C low
0D mid
0E high
Cheers-
E
Old Mar 31, 2008 | 07:56 PM
  #67
nonschlont's Avatar
make sure u have the 0 before the " . " in the formula. that worked foe me.
  #68
To help me sleep at night, literally highlight this formula, copy it and paste it into evoscan for me. Just amuse me,lol. Having the '0' added makes all the difference
(0.1961*x)-25
If its not that, something is up with evoscan or your MUT table addresses.
Old Mar 31, 2008 | 08:05 PM
  #69
Wicked E's Avatar
OWNED!! No 0 before the (.)
I'm going back to my corner of the interweb now...
Cheers-
E
Old Mar 31, 2008 | 08:06 PM
  #70
nonschlont's Avatar
I havent been able to edit any of my .xml for some reason... IDK what I am doing wrong... I edit from where its located, and still cant get it done. where can I dl this SP1
Old Mar 31, 2008 | 08:11 PM
  #71
Its best to edit it in evoscan with the new version.
Old Mar 31, 2008 | 09:47 PM
  #72
dawnduran's Avatar
Should anybody fix the complete data.xml with all the bugs and post the file here?!
Thank you.
Old Apr 1, 2008 | 10:54 AM
  #73
nonschlont's Avatar
I think he meant COULD any1 post up the complete data .xml file?
Old Apr 1, 2008 | 11:34 AM
  #74
I'll see what I can do soon.
Old Apr 2, 2008 | 02:57 PM
  #75
nonschlont's Avatar
OK I just figured out what I was doing wrong w/ a lil help, I was using an .xml file from a different ecuflash version. Also learned that there is a difference between v 1.30 and under, from v 1.31 or later!
