evoscan 2.1 problems and fixes
For anyone upping the ante to 2.2b
RPM 2-byte
2.1 fix: 1000*x/256
2.2 value: 3.906*x
I believe these are the same, there may be the smallest rounding error (actual is 3.90625) but I think I'll probably stick with the default.
RPM 2-byte
2.1 fix: 1000*x/256
2.2 value: 3.906*x
for guys using the tephra v5 and need to know the raw volt coming from the ADC input or to see if your in your alt map using evoscan
you can setup a new MUT request to log 0xFFFF8425, if its 0 then you are on standard maps, if its on 3 then you are on altmaps. The evoscan address below is requesting ID 08, so I would go into my MUT table change the value thats was currently there to 8425.
<DataListItem DataLog="N" Color="" Display="Map Switching" LogReference="Map Switching" RequestID="08" Eval="x" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="500" ChartMin="0" ChartMax="500" ScalingFactor="1" Notes="0= standard map 3= alt map" Priority="1" Visible="False" />
0= 0 volts 255=5 volts
<DataListItem DataLog="N" Color="" Display="ADC Input Signal" LogReference="ADC Input Signal" RequestID="83" Eval="x" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="500" ChartMin="0" ChartMax="500" ScalingFactor="1" Notes="0=0 volts 255= 5 volts" Priority="1" Visible="False" />
I dont think this a problem or fix, LOL
edit*** dont request ID 06, that is for timing
just do the mrfred mod, did it to my ngk wideband works like a champ
https://www.evolutionm.net/forums/sh...d.php?t=337823
can logworks read the analog output from your lc-1
lol it hasnt worked right since .97 and I see no effort or very little to address the multitude of problems in this If I thought it would work I would ask for a full refund since I purchased the .9x and the 2.x versions. Oh and upgrades are free he tells me . Too bad every upgrade breaks something else and what about the maptracer why does changing the injector scaling under load from 513 to any value break it completely?
Am not sure if it's a mistake or correct reading, I'm getting
Display="Fuel Trim Low (LTFT)" LogReference="FuelTrim_HIGH" RequestID="0C"
Display="Fuel Trim Mid (LTFT)" LogReference="FuelTrim_Mid" RequestID="0D"
Display="Fuel Trim High (LTFT)" LogReference="FuelTrim_Low" RequestID="0E"
The data.xml is unaltered. Should displayed, fuel trim low same as log reference fuel trim_low? Same goes for fuel trim high.
