Official 2 byte thread!
Old Oct 6, 2013 | 12:39 PM
  #346
masjadrashid's Avatar
I have tried to look for the 3d mut table down load and its not allowing me to open it, its like its broken. I am running a 88570008 evo 9 jdm rom on my car and i would like to add the mut table and other areas that i can tune with. Can any one send me a link for the 3d table? would really appreciate it since i have gone through the whole of this forum and i cant seem to find it.
Thanks
Old Oct 6, 2013 | 01:13 PM
  #347
todd6027's Avatar
add this to your evo9 base xml
<table name="MUT Table" category="MUT" type="3D" level="2" scaling="Hex16">
<table name="X" type="Static X Axis" elements="32" scaling="Hex16">
<data>-</data>
<data>0</data>
<data>-</data>
<data>1</data>
<data>-</data>
<data>2</data>
<data>-</data>
<data>3</data>
<data>-</data>
<data>4</data>
<data>-</data>
<data>5</data>
<data>-</data>
<data>6</data>
<data>-</data>
<data>7</data>
<data>-</data>
<data>8</data>
<data>-</data>
<data>9</data>
<data>-</data>
<data>A</data>
<data>-</data>
<data>B</data>
<data>-</data>
<data>C</data>
<data>-</data>
<data>D</data>
<data>-</data>
<data>E</data>
<data>-</data>
<data>F</data>
</table>
<table name="Y" type="Static Y Axis" elements="30">
<data>MUT0X</data>
<data>MUT1X</data>
<data>MUT2X</data>
<data>MUT3X</data>
<data>MUT4X</data>
<data>MUT5X</data>
<data>MUT6X</data>
<data>MUT7X</data>
<data>MUT8X</data>
<data>MUT9X</data>
<data>MUTAX</data>
<data>MUTBX</data>
<data>MUTCX</data>
<data>MUTDX</data>
<data>MUTEX</data>
<data>MUTFX</data>
<data>MUT10X</data>
<data>MUT11X</data>
<data>MUT12X</data>
<data>MUT13X</data>
<data>MUT14X</data>
<data>MUT15X</data>
<data>MUT16X</data>
<data>MUT17X</data>
<data>MUT18X</data>
<data>MUT19X</data>
<data>MUT1AX</data>
<data>MUT1BX</data>
<data>MUT1CX</data>
<data>MUT1DX</data>
</table>
then add this to your 88570008 xml
<table name="MUT Table" address="35920">
<table name="X"/>
<table name="Y"/>
</table>
Old Oct 6, 2013 | 01:18 PM
  #348
todd6027's Avatar
88570008
2 byte load
mut00 6b12
mut01 6b13
2byte rpm
mut02 6afe
mut03 6aff
Old Jan 22, 2014 | 06:03 AM
  #349
MacMan's Avatar
why are the values in this thread not implemented into the latest V7 roms?
Old Sep 6, 2014 | 06:02 PM
  #350
holydevil's Avatar
97400004
how do i find this 2byte load , SH-7052
Old Oct 9, 2014 | 10:35 PM
  #351
stunt2's Avatar
is 898A & 898B correct 2byte load for 9653 ?
I need baro+iat compensated one
Old Nov 17, 2014 | 06:53 PM
  #352
Rpf1evolution's Avatar
latest evoscan says not to use 2byte load as it is slower then load1byte. im trying to figure out which one to use so i can log load. never get any to the point answers. all i can find is how to do one or the other but nothing says which one to use over the other. any help appreciated
Old Nov 18, 2014 | 03:26 AM
  #353
todd6027's Avatar
2byte load more than adequate for logging
Old Nov 18, 2014 | 08:46 PM
  #354
so i tried to do the 2 byte load thing. my adress is right as far as i know according to this thread. and also i changed to mut 00 01 . when i log it its showing something like 9XXX which is really not even close to right. im not sure whats going on . when logging loadcalc i get values up into the 450s. i dont think its really getting that high but again im not sure.
quick rundown
precision 1200
double pumper
fp black
E85
built motor
S1 cams
TBE
hallman pro MBC
all piping, ams fmic, intake
my log is showing 507/438 at 30 psi at 10.5 afr timing from 2* to 16*
i would like my load to log correct so i can lean this thing out and see what shes got.
Old Nov 19, 2014 | 02:06 PM
  #355
todd6027's Avatar
quick rundown
precision 1200
double pumper
fp black
E85
built motor
S1 cams
TBE
hallman pro MBC
which rom ??
Old Nov 21, 2014 | 10:11 AM
  #356
which rom ??
the 96940011 05 UDSM
since then, i rescaled the maf and now my afrs went from 10.5 all the way through to 11.5 all the way through. made 510hp at 25 psi instead of 30 before the fix. but i would like to get this 2 byte load to work. now loadcalc is reading at max about 360 so that seems about right. thanks for the replys so far. this is really a fun car now. a jump from 370hp to 510 feels really nice.
Old Nov 21, 2014 | 12:28 PM
  #357
arrghh this is frusatrating to say the least. i have to correct mut table adresses set. ticked off 2 byte load in evoscan and its still gives me some random values. ive tried using about every function equation i could find and nothing even comes close. i have got to be missing something. can somebody throw something out there to point me in a direction. i have read so many how to this and that and everything i have tried is not working. something is missing somewhere. im not sure if there is evoscan xml to add or anything. that may be a problem. or xml to edit to find certain adresses. thank you in advance
Old Nov 21, 2014 | 01:28 PM
  #358
todd6027's Avatar
In Evoscan 2 byte load request = 00 and function =0.3125*x
Old Mar 25, 2015 | 06:11 PM
  #359
butte's Avatar
Does anyone know how much peak load a stock evo 9 should expect? Sorry if this has been answered, I tried googling around and searching the forums with no success
Old Apr 28, 2015 | 02:06 PM
  #360
89Saleen141's Avatar
Hey, I'm in the same boat as Rpf1evolution. Same rom 96940011, all the data is there. I have evoscan 2.9 with Mut2byte airflow and load preset. Both are gathering info from the corresponding 00 01 and 04 05 MUT addresses which is already visible to me. I cannot get a usable number from 2byte load. The equations are correct as well. It does say in the description that I need a tephra modded rom. Should I try switching Rom I'ds and take a second go at it?
