Official 2 byte thread!
Old Apr 18, 2012 | 07:27 PM
  #331
evo3gsx's Avatar
Originally Posted by awdordie
you got pm^
Will you please pm me the MUT table? Also, I'm running 94170715 V7 and have 2byte working using 895C, 895D for MUT 00, 01 respectively but I'm in UT and saw the post above about these addresses being uncompensated. I changed the MUT addresses 00, 01 to 8960, 8961 and 2byte isn't working. Are these the addresses I need to be changing to get compensated load?
Old May 8, 2012 | 12:43 AM
  #332
YaroRS's Avatar
2 bite load for Evo 9 GT 89280002 rom and 88570008
load
6b12 6b13
6b14 6b15
6b16 6b17
rpm 2 byte
6aee 6aef
airflow
6b6e 6b6f
Old May 11, 2012 | 09:34 AM
  #333
Mellon Racing's Avatar
Originally Posted by EvocentriK
Can anyone please help me with 2-byte airflow for 90550001 ?
try these:
04: 88B4
05: 88B5
Old May 12, 2012 | 09:02 AM
  #334
EvocentriK's Avatar
Thanks mate i'll give them a go
Old Jun 9, 2012 | 11:44 PM
  #335
darksideauto's Avatar
Can anyone help my with 2 byte load and airflow for 51510023? Thanks in advance for any assistance!
Old Nov 9, 2012 | 09:58 AM
  #336
steven121's Avatar
OK so I finally got the mut table in my rom do I still need to download the 3D mut table xml definition? and not sure where to put mut00 and mut01 in rom ID 94170715
Trying to figure out where to finish at
help please
Old Mar 18, 2013 | 11:57 AM
  #337
Terror Rising's Avatar
Alright, I'm new to using ECUFlash and EvoScan but I'm reading all I can. I was able to install my Omni 4-bar, add it to the 94170008 XML file, log it with EvoScan, and it seems to be working properly. I've also added the 3D MUT table and as far as I can tell I did that correctly, too. I'm trying to add 2-byte load but can't get it to work. Everything I've looked up is for the proper 94170008 ROM so I don't know what I'm doing wrong. Here's all I've added so far:
4 Bar OmniPower MAP
<table name="MAP Test 1: Mid VE Max Voltage" category="MAPSensor" address="2048" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 1: Mid VE Min Voltage" category="MAPSensor" address="2046" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 2: Low VE Max Voltage" category="MAPSensor" address="204C" type="1D" level="1" scaling="Volts16"/>
<table name="MAP Test 3: High VE Min Voltage" category="MAPSensor" address="2050" type="1D" level="1" scaling="Volts16"/>
Changed in ECUFlash
MAP Test 1: Mid VE High Voltage Test -- Change from 4.61 volts to 4.90 volts.
MAP Test 1: Mid VE Low Voltage Test -- Change from 0.10 volts to 0.06 volts.
MAP Test 3: High VE Voltage Test -- Change from 1.80 volts to 0.51 volts.
In ECUFlash, find the "Periphery2 (FCA) Bits" table. Change bit.9 from 1 to 0. Use the "minus" key on the keyboard. This disables the P0401 (EGR) test.
Changed in EvoScan
Boost(MAP) = 0.2369*x-14.3 (750 ft correction)
MUT Table
<table name="MUT table" category="Misc" address="38060" type="3D" level="1" scaling="Hex16">
<table name="X" type="Static X Axis" elements="32" scaling="Hex16">
<data>-</data><data>0</data>
<data>-</data><data>1</data>
<data>-</data><data>2</data>
<data>-</data><data>3</data>
<data>-</data><data>4</data>
<data>-</data><data>5</data>
<data>-</data><data>6</data>
<data>-</data><data>7</data>
<data>-</data><data>8</data>
<data>-</data><data>9</data>
<data>-</data><data>A</data>
<data>-</data><data>B</data>
<data>-</data><data>C</data>
<data>-</data><data>D</data>
<data>-</data><data>E</data>
<data>-</data><data>F</data>
</table>
<table name="Y" type="Static Y Axis" elements="30">
<data>MUT0X</data>
<data>MUT1X</data>
<data>MUT2X</data>
<data>MUT3X</data>
<data>MUT4X</data>
<data>MUT5X</data>
<data>MUT6X</data>
<data>MUT7X</data>
<data>MUT8X</data>
<data>MUT9X</data>
<data>MUTAX</data>
<data>MUTBX</data>
<data>MUTCX</data>
<data>MUTDX</data>
<data>MUTEX</data>
<data>MUTFX</data>
<data>MUT10X</data>
<data>MUT11X</data>
<data>MUT12X</data>
<data>MUT13X</data>
<data>MUT14X</data>
<data>MUT15X</data>
<data>MUT16X</data>
<data>MUT17X</data>
<data>MUT18X</data>
<data>MUT19X</data>
<data>MUT1AX</data>
<data>MUT1BX</data>
<data>MUT1CX</data>
<data>MUT1DX</data>
</table>
</table>
Changed in ECUFlash
MUT00 = 895C (original = 888F)
MUT01 = 895D (original = 888E)
2 Byte Load
<table name="00 2 byte load" address="38062" type="1D" level="1" scaling="uint16" />
<table name="01 2 byte load" address="38066" type="1D" level="1" scaling="uint16" />
Changed in ECUFlash
00 2 byte load = 35164
01 2 byte load =35165
Changed in EvoScan
Load MUT 2Byte Mod = 1000*x/256 (original is 0.3125*x)
Here's a sample of what my CalcLoad and MUT2 Load are in EvoScan:
Load Calc: 16.74
Load MUT2: 296.88
Load Calc: 27.00
Load MUT2: 464.84
Load Calc: 73.02
Load MUT2: 1003.91
Load Calc: 149.78
Load MUT2: 1953.13
Load Calc: 199.27
Load MUT2: 2660.16
Is it not displaying correctly due to the settings highlighted in the ECUFlash section of two byte load?
Old Apr 28, 2013 | 11:43 AM
  #338
nj1266's Avatar
94170008 MUT table. Just copy and paste into xml file.
<table name="MUT Table" category="Misc" address="38060" type="3D" level="1" scaling="Hex16">
<table name="X" type="Static X Axis" elements="32">
<data>-</data>
<data>0</data>
<data>-</data>
<data>1</data>
<data>-</data>
<data>2</data>
<data>-</data>
<data>3</data>
<data>-</data>
<data>4</data>
<data>-</data>
<data>5</data>
<data>-</data>
<data>6</data>
<data>-</data>
<data>7</data>
<data>-</data>
<data>8</data>
<data>-</data>
<data>9</data>
<data>-</data>
<data>A</data>
<data>-</data>
<data>B</data>
<data>-</data>
<data>C</data>
<data>-</data>
<data>D</data>
<data>-</data>
<data>E</data>
<data>-</data>
<data>F</data>
</table>
<table name="Y" type="Static Y Axis" elements="16">
<data>0</data>
<data>1</data>
<data>2</data>
<data>3</data>
<data>4</data>
<data>5</data>
<data>6</data>
<data>7</data>
<data>8</data>
<data>9</data>
<data>A</data>
<data>B</data>
<data>C</data>
<data>D</data>
<data>E</data>
<data>F</data>
</table>
</table>
Old Apr 28, 2013 | 11:45 AM
  #339
nj1266's Avatar
94170015 MUT table. Copy and paste into XML file.
<table name="MUT Table" category="Misc" address="38158" type="3D" level="1" scaling="Hex16">
<data>-</data>
<data>0</data>
<data>-</data>
<data>1</data>
<data>-</data>
<data>2</data>
<data>-</data>
<data>3</data>
<data>-</data>
<data>4</data>
<data>-</data>
<data>5</data>
<data>-</data>
<data>6</data>
<data>-</data>
<data>7</data>
<data>-</data>
<data>8</data>
<data>-</data>
<data>9</data>
<data>-</data>
<data>A</data>
<data>-</data>
<data>B</data>
<data>-</data>
<data>C</data>
<data>-</data>
<data>D</data>
<data>-</data>
<data>E</data>
<data>-</data>
<data>F</data>
</table>
<data>0</data>
<data>1</data>
<data>2</data>
<data>3</data>
<data>4</data>
<data>5</data>
<data>6</data>
<data>7</data>
<data>8</data>
<data>9</data>
<data>A</data>
<data>B</data>
<data>C</data>
<data>D</data>
<data>E</data>
<data>F</data>
</table>
</table>
Old Apr 28, 2013 | 11:47 AM
  #340
nj1266's Avatar
Tell me if you want any others. I will post what I have since the link on the firrst page is broken.
Old Apr 28, 2013 | 09:14 PM
  #341
sandman121383's Avatar
hey i have rom id 96420008
i seen someone post that the mut address was 39fa0.
on evoecu it's 38158
http://evoecu.logic.net/wiki/96420008
can someone confirm which is correct?
also what is the best way to calc and log load. i see 2 byte posts and 1 byte tephra posts.
Old May 25, 2013 | 06:59 PM
  #342
mines5's Avatar
Hi , i am new to ECU flash
rom 93660005
Can any one paste a command to add MUT table to the rom image
also for 2 byte load and 2 byte rpm
ill use mitsulogger.
Kindly tell me where to paste in the xml file.
Thanks
Old May 29, 2013 | 08:13 PM
  #343
Kakihara's Avatar
Can anyone tell me how to change the Y axis values properly when using 2byte airflow in maf raw scaling ?
I did it a few year ago but can't remember how you do it. If I just copy paste the values from my old 2byte activated rom I end up with crazy numbers...
From what I remember there's a trick that goes a bit like this :
- switch the Y axis to another type of scaling/units (uint8 ? 16 maybe)
- use some kind of multiplication to translate the values you really want (Hz) into that kind of scaling (for ex. instead of having 2000Hz you input maybe 3234578)
- switch the Y axis to the regular scaling/unit and voila you have your 2000hz
I could get pretty much a 1:1 afrmap/real afr with 2byte airflow maf rescaling
Old Jun 2, 2013 | 03:31 PM
  #344
Kakihara's Avatar
I answer to myself in the maf rescaling thread : https://www.evolutionm.net/forums/ec...f-pics-11.html
Old Jul 2, 2013 | 06:09 PM
  #345
FullBlown8's Avatar
need help immediately
I have rom 96420008.. was able to add a mut table.. got it all added in but when I opened it in ecu flash I could select mut table but it gave me an error that the table was incomplete... couldn't get it to work... then I just went to the tephra v7 94170715 and I cant find any of the 2 byte load, rpm, air flow info... need assistance
