Official 2 byte thread!
Old Nov 3, 2009 | 05:40 AM
  #271
Fast_Freddie's Avatar
Veteran: Navy
Originally Posted by TTP Engineering
Are the 96531706 and 0706 the same as 96530006?
Yes there are both "builds" of the 9653006 rom...
Old Nov 24, 2009 | 09:39 AM
  #272
daymean's Avatar
Guys the current values used for 2byte load for 96260009 -
MUT 00 = 0x8984
MUT 01 = 0x8985
I am wondering if these are the 2-byte LOAD_Raw (no temp compensation) values when we should infact be using 2-byte LOAD_Temp_and_Baro_Compensated -
MUT 00 = 0x898A
MUT 01 = 0x898B
Old Nov 30, 2009 | 08:35 PM
  #273
_DEN_'s Avatar
Originally Posted by GregM
Any one with info for 89970010?
MUT Table address="33A7c" - need to verify
AT MUT table address="7F784" - I think it's same as EVO 7.5 GTA
Old Dec 1, 2009 | 10:19 AM
  #274
GregM's Avatar
Thank you, will give it a try.
Old Dec 1, 2009 | 10:42 AM
  #275
GregM's Avatar
Does this look right?
Old Dec 1, 2009 | 07:49 PM
  #276
_DEN_'s Avatar
Yes, but I hevn't any mods like 2 byte load, RPM ...
Old Dec 4, 2009 | 04:37 AM
  #277
Jobi's Avatar
Any chance of getting 2 byte load for Evo6s?
ROM 24430002 or 25570000
It would defo be greaaaaaaaat!
Old Jan 28, 2010 | 08:38 AM
  #278
raasfaas's Avatar
need a little help here setting up my friends JDM IX (80920002) to log 2 byte load. I know that this romid is not very popular and I have to inherit from 88570008 but when I make the changes in the MUT table (00=0x6b12 and 01=0x6b13) 2 byte load reads in the 1000xs and my timing goes static and logs at -20.
Not sure how that affected logging timing because it looks up request id 06.
Not sure if this info is necessary but I'm using V1.29a, with evoscan v2.5
Anyone know whats going on here?
Old Jan 29, 2010 | 05:09 AM
  #279
raasfaas's Avatar
^^anyone know what the MUT values are for logging 2 byte load on 80920002??
Old Apr 6, 2010 | 02:23 AM
  #280
_DEN_'s Avatar
2byte load for 89970010
MUT 00 = 0x8B0A
MUT 01 = 0x8B0B
need to check it
Old Jun 2, 2010 | 07:27 AM
  #281
3gEclipseTurbo's Avatar
mut 00,01,02,03,04,05 works like in math where the first number is the x axis and the second number is the y axis right?
Old Jun 2, 2010 | 09:05 AM
  #282
Raptord's Avatar
No, first is the Y axis and second number is the X axis. That's why "MUT0X" is the first scale in the y axis, it's for all MUT addresses that start with MUT0. After that replace the "X" with the number in the X axis for the cell you're looking at.
Old Jun 8, 2010 | 06:41 PM
  #283
5LEEPERISAH23I's Avatar
Originally Posted by AlwaysinBoost
96420011
2byte load
MUT 00 =
MUT 01 =
2byte RPM
MUT 02 =
MUT 03 =
2byte AirFlow
MUT 04 =
MUT 05 =
MUT 3D TABLE ADDRESS =
^^^^^^^anyone know the info for 96420011????
+1 need also
Old Jun 23, 2010 | 10:35 AM
  #284
wip's Avatar
wip
Originally Posted by Jack_of_Trades
88570008
2byte load
MUT 00 = 6B12
MUT 01 = 6B13
2byte RPM
MUT 02 = 6AFE
MUT 03 = 6AFF
2byte AirFlow<-----------------------------------Need Confirmation
MUT 04 = 6B6A
MUT 05 = 6B6B
MUT 3D TABLE ADDRESS = 35920
2byte airflow (working)
6B6E
6B6F
Taken from this thread:
http://www.lancerregister.com/showthread.php?t=134923
Old Jul 16, 2010 | 01:48 PM
  #285
Timmay81's Avatar
great info
