Official 2 byte thread!
Old Aug 12, 2009 | 02:50 AM
  #256
Yamahar1's Avatar
Originally Posted by kaj
i opened up my evoscan and the boxes where there to check.. but i could swear it's 'cause i added something before...
or does the new version i downloaded come with it already? sorry. i haven't touched evoscan in a while.. 'been trying to get my ecuflash rom right.
anyway: it's listed as boxes i can check to log.
Well damn, I must be doing it wrong then. I don't have boxes to check....In the MUT table I put the following in....right?
96420008<------------the ROM I have
2byte load
MUT 00 = 8984
MUT 01 = 8985
2byte RPM
MUT 02 = 8962
MUT 03 = 8963
2byte AirFlow
MUT 04 = 89E2
MUT 05 = 89E3
Muttable.png?t=1250107603
Old Aug 24, 2009 | 10:36 PM
  #257
Evo_Jay's Avatar
Originally Posted by eitan
96420011 MUT 3D address = 3a0bc.
this seems correct. OP should update the first post with this new info.
Old Sep 11, 2009 | 07:56 AM
  #258
warp9's Avatar
So I cant do the load and airflow with my rom# 96420007..just rpm? Any help would be great
2byte load
MUT 00 =
MUT 01 =
2byte RPM
MUT 02 = 8962
MUT 03 = 8963
2byte AirFlow
MUT 04 =
MUT 05 =
Old Sep 11, 2009 | 08:52 PM
  #259
warp9's Avatar
Too bad my name wasnt DB...I would have gotten tons of help!
Old Sep 11, 2009 | 08:54 PM
  #260
tephra's Avatar
it will be the same numbers as 96420008...
Old Sep 11, 2009 | 08:55 PM
  #261
warp9's Avatar
Thanks tephra
Old Sep 12, 2009 | 11:10 PM
  #262
GregM's Avatar
Any one with info for 89970010?
Old Sep 23, 2009 | 11:46 AM
  #263
Raceghost's Avatar
Can someone confirm all the 2byte formulas for Evoscan. I am getting some very weird, very high load values in the 2 byte column, like 100 points more that with the regular calc load, or ecu load. It is making tuning rather difficult. I have verified that the ROM 2byte load mut table addresses are correct, so that leaves evoscan miscalculating or reading the signal.
Here is what I have in EVOSCAN V2.5
EVOSCAN Formulas as follows:
2byte load 0.3125*x
2byte RPM 1000*x/256 (correct per post 1)
2Byte AIRFlow 6.29*x/64
Thanks in advance.
Old Sep 24, 2009 | 12:21 PM
  #264
Walt's Avatar
Hey guys, i just put the patch in for 2 byte and for some reason when i pull the mut table up in ecuflash to try to change the values for mut 00 to start it's not changing the value... I'm putting in '0x'6B42 for rom id 88590015 for mut 00 and the value is staying the same when i hit enter.. I am a newbie and tried everything to get the code changed.. Please help thanks!!!
Old Sep 24, 2009 | 02:39 PM
  #265
Raceghost's Avatar
you are right clicking with your mouse and selecting "set data =" or something similiar is the command. Should work. Also, make sure you are at the developer level.
Any one varify my formulas yet?
Old Sep 27, 2009 | 04:39 AM
  #266
Armanc1's Avatar
Originally Posted by al\lupo
Here are the addresses for 88840016 & 17:
88840016
2byte load
MUT 00 = 6B22
MUT 01 = 6B23
2byte RPM
MUT 02 = 6AFE
MUT 03 = 6AFF
2byte AirFlow
MUT 04 = 6B7E
MUT 05 =6B7F
MUT 3D TABLE ADDRESS = 377F8
88840017
2byte load
MUT 00 = 6B22
MUT 01 = 6B23
2byte RPM
MUT 02 = 6AFE
MUT 03 = 6AFF
2byte AirFlow
MUT 04 = 6B7E
MUT 05 = 6B7F
MUT 3D TABLE ADDRESS = 37944
I checked the values in asm for both, also airflow for 17 is the same of 16. MUT table are located in different places.
I am getting weird reading with these values on 2byte LOAD and RPM as well. I am using 88840016 ROM. Any help much appreciated. Shall I change something in Evoscan? I checked all the formulas and they are correct. I am running EvoScan v2.6. I am lost here....
Old Oct 23, 2009 | 12:18 AM
  #267
Danieln's Avatar
Somebody can help me please with 88580015 2 byte addresses?
Mut table is into the same position with 88580013 and 14 (373c4) but the address for load 2byte or rpm2byte are not the same I think.
I get strange readings when I log 2byte
Old Oct 23, 2009 | 07:43 AM
  #268
logic's Avatar
Actually, the MUT table is at 374DC on the copy of 88580015 that I have here.
The 2-byte addresses all look the same as 88580013.
Old Nov 3, 2009 | 01:20 AM
  #269
TTP Engineering's Avatar
Are the 96531706 and 0706 the same as 96530006?
Old Nov 3, 2009 | 01:33 AM
  #270
Evo_Jay's Avatar
Yes, I believe so.
