Official 2 byte thread!
Old Apr 9, 2008 | 02:48 PM
  #106
nonschlont's Avatar
cheers
Old Apr 9, 2008 | 03:53 PM
  #107
sub7's Avatar
Can someone find the 2byte load for 89970017 and 83540001 (inherit 89970010)
89970017
83540001/89970010
Old Apr 10, 2008 | 10:34 AM
  #108
sub7's Avatar
For 93660005, it should be:
2byte load
RequestID0 = 893E
RequestID1 = 893F
2byte rpm
RequestID2 = 8960
RequestID3 = 8961
MUT table = 33400
Old Apr 10, 2008 | 11:11 AM
  #109
bboy's Avatar
Jack o' Trades I think this is worth adding to top of your thread.
The 12 Step Program for adding 2Byte Logging Ability to Your ROM File
Here are the expanded directions in the 3D MUT Table MOD that you may download in the "Official 2 Byte Thread"-- for the Newbie in all of us:
0) Upload your ROM from the cars ECU with EcuFlash (Tactrix cable, laptop, EcuFlash, etc, required)
1) Click the + next to ROM Data to find out which ECU build you are working with. There should be an 8 digit number like 88590015 in there.
2) Save your ROM file with somename.hex and exit ECUFlash
3) Now navigate to the folder /Program Files/OpenECU/ECUFlash/rommetadata/mitsubishi/evo/
4) Find your ECU definition file--it's the number you read out of the ROM Data above, examples include 88590015 or 96940011. I'm generalizing it to ##ECUID##.xml
5) Open the ##ECUID##.xml file with Notepad (right click "open with" Notepad)
6) Open the 3D MUT Table that you downloaded from the top of this thread with Notepad.
7) Copy and paste the table /table code into the XML definition file found in /Program Files/OpenECU/ECUFlash/rommetadata/mitsubishi/evo/##ECUID##.xml that you have open in Notepad.
8) Copy the appropriate MUT TABLE ADDRESS for your ECU. I used 3EE84 for a 88590015-type ECU on an Evo 9 I was working on and 3F314 for a 96940011-type ECU Evo 8 I was working on. This number is found in this thread (2Byte Thread) below the appropriate ECU ID number.
9) Copy/paste of the "MUT 3D TABLE ADDRESS =" data in the spot that says: ENTER YOUR MUT TABLE ADDRESS HERE! This number (like 3F314) needs to be within the quotation like this "3F314". Now SAVE the ##ECUID##.xml file with the updated table code.
10) Now SAVE the ##ECU##.xml file with the updated table code. In one case 88590015.xml found in the ~/mitsubishi/evo folder in the OpenECU program file.
11) Reopen your ECU ROM file that you uploaded from the ECU with EcuFlash, and you should now see a new table in the Misc section called 3D MUT table. Open this table.
12) Now edit the cells in the table with the addresses 00 (e.g. 0 row, 0 column), 01 (0 row, 1 column), 02, and 03 with the appropriate HEX values. You will have to highlight the cell, hit the = key, then type in 0x + the HEX value. For instance, 0x899A for the 00 cell in the 96940011-type ROM (see 2Byte Thread). That is zero x that precedes each HEX value as indicated in the window in EcuFlash. Save the ROM file with new name. You are ready to log using 2Byte data.
Old Apr 16, 2008 | 05:13 AM
  #110
DCsleeper's Avatar
Confirming 2Byte Addresses for ROM 94170015:
2BYTE LOAD
MUT 00 = 895C
MUT 01 = 895D
2BYTE RPM
MUT 02 = 893A
MUT 03 = 893B
2BYTE AIRFLOW
MUT 04 = 89BA
MUT 05 = 89BB
I am currently logging all three of these on this ROM with no issues.
Old Apr 22, 2008 | 06:34 AM
  #111
tephra's Avatar
88580013/4 2byte airflow should be 0xffff6b7e
Old Apr 24, 2008 | 09:30 PM
  #112
Jack_of_Trades's Avatar
Updated, thanks guys!
Old Apr 25, 2008 | 07:57 AM
  #113
tephra's Avatar
Jamie - maybe PM a mod and ask them to delete replies so we can clean this thread up a little
Old Apr 25, 2008 | 09:37 AM
  #114
Christ, I don't even know who is a mod on here,lol. Know anyone who mods this area?? I also should have them change the title to "Official 2 byte/MUT Table Thread" as well.
Old Apr 25, 2008 | 01:42 PM
  #115
chmodlf's Avatar
I think these are the mods for this area
althemean, timzcat, Speedlimit, chaotichoax
Old Apr 27, 2008 | 02:30 AM
  #116
xpro's Avatar
any info on 88570008 rom. I need table address to set up 2 byte load.
help appriciated
phil
Old Apr 27, 2008 | 02:28 PM
  #117
Underated's Avatar
how do you find the MUT TABLE ADDRESS for your ECU if its not listed?
Old Apr 27, 2008 | 02:31 PM
  #118
Beg someone on here who is good with ECU disassembly,lol.
Old Apr 27, 2008 | 06:46 PM
  #119
tephra's Avatar
3D MUT TABLE for 88570008 is 0x35920
Old Apr 28, 2008 | 02:27 AM
  #120
xpro's Avatar
thanks man
