Official 2 byte thread!
Old Mar 18, 2008 | 08:30 PM
  #76
Jack_of_Trades's Avatar
Why do you need to see a list of ALL of them?
Old Mar 18, 2008 | 08:56 PM
  #77
tephra's Avatar
90550001:
MUT_TABLE: 0x2e9e0
Load: 0xFFFF885C
RPM: 0xFFFF883A
88580013/4:
MUT_TABLE: 0x373c4
Load: 0xFFFF6B22
RPM: 0xFFFF6AFE
96530006:
RPM: 0xFFFF8962
Old Mar 19, 2008 | 03:19 PM
  #78
SuPeRNeT's Avatar
Does any one know were i can get a 96420008 stock rom??
Old Mar 19, 2008 | 03:36 PM
  #79
SoCalRedLine's Avatar
^aktivematrix
Old Mar 19, 2008 | 04:25 PM
  #80
tephra's Avatar
We kinda think 96420008 was some tuners upgrade of 96420007!
As no one seems to have a stock 96420008
Old Mar 19, 2008 | 04:31 PM
  #81
cossie1's Avatar
Originally Posted by tephra
90550001:
MUT_TABLE: 0x2e9e0
Load: 0xFFFF885C
RPM: 0xFFFF883A
88580013/4:
MUT_TABLE: 0x373c4
Load: 0xFFFF6B22
RPM: 0xFFFF6AFE
96530006:
RPM: 0xFFFF8962
Cheers Dave
Old Mar 20, 2008 | 11:01 AM
  #82
SuPeRNeT's Avatar
Do you mean no one has a stock 20007 rom? I cant get the 96420008 ecuflash to show the MUT table.. Can any one conferm that MUT 3D TABLE ADDRESS = 39FAO Is right? I keep getting a parse error tag mismatch when i open ecuflash after altering the xml..
Old Mar 20, 2008 | 11:40 AM
  #83
Make sure you didn't miss a tag in the coding. I sometimes delete a > or a < in the code by mistake at times. Also make sure that for every < table > code that you have an ending < /table > code at the end.
Does it tell you a line number where the error occurs? Thats the line number in Notepad where the XML error is, usually on the bottom taskbar (in Notepad, go to the top taskbar and click "VIEW" and checkmark 'Status Bar') you can see the line number as you move the cursor down the page.
Old Mar 20, 2008 | 12:30 PM
  #84
R. Mutt's Avatar
I think 2byte rpm for 98640014 is:
MUT 02 = 883A
MUT 03 = 883B
unconfirmed though, just via IDA pro
Old Mar 20, 2008 | 06:29 PM
  #85
SuPeRNeT's Avatar
Originally Posted by Jack_of_Trades
Make sure you didn't miss a tag in the coding. I sometimes delete a > or a < in the code by mistake sometimes. Also make sure that for every < table > code that you have an ending < /table > code at the end.
Does it tell you a line number where the error occurs? Thats the line number in Notepad where the XML error is, usually on the bottom taskbar you can see the line number as you move the cursor down the page.
Thanks that helped me out!!
Old Mar 20, 2008 | 06:41 PM
  #86
90550001:
MUT_TABLE: 0x2e9e0
Load: 0xFFFF885C
RPM: 0xFFFF883A
88580013/4:
MUT_TABLE: 0x373c4
Load: 0xFFFF6B22
RPM: 0xFFFF6AFE
96530006:
RPM: 0xFFFF8962
Updated, thanks.
Old Mar 22, 2008 | 11:44 AM
  #87
alicea8541's Avatar
never mind
Last edited by alicea8541; Mar 22, 2008 at 01:51 PM. Reason: figured out my problem
Old Mar 25, 2008 | 11:58 AM
  #88
tseitz123's Avatar
96530006 2Byte Airflow? Anyone? Anyone?
Old Mar 25, 2008 | 11:24 PM
  #89
R. Mutt's Avatar
ok so I tested out the 2byte rpm fo 98640014. I don't think it was right but I got a graph that mirrors rpm but the scaling is off:
Engine rpm
2byte rpm
Any recommendations? This is what I had:
MUT 02 = 883A
MUT 03 = 883B
Mar 20, 2008 10:40 AM
Old Mar 26, 2008 | 12:06 PM
  #90
tseitz123's Avatar
bump for my last post
