Car is Pissing me off! Help!
ok so i got a 2006 JDM Evo IX. i got it second hand doing 10000kms. so far i have changed fluids.
so i started logging with Evoscan and realised to my suprise i am getting 20-25 counts of knock. DAMN!!
so with the help of a very knowledgable tuner in trinidad we started adjusting timing only (no WB).WB going in this weekend.
we got the knock down to 10-13 knocks when in WOT 3rd gear pull.
but from there i tried a couple maps and the knock wont come down!!!
after seeking help ppl told me to do a boost leak test...Done! no boost leak.
changed spark plugs....good...still getting the same knock...
the only thing i can think is a bad knock sensor?????
there is one more factor that is out of my knowledge, my car is a GSR but i have a GT ECU in the car (long story!) but running maps suited for the GSR....will this cause a problem?
i can post my rom and log i did last night if u guys wanna see....i am completely lost.
did you check the knock filters in the GT rom to see if it matched the GSRs rom? that could be the factor, cause the threshholds could be off, post your rom and i will take a look at it.
What is your list of Mods? Try adding race gas or toluene to the tank of fuel and see if the knock reduces.
Are you 100% sure the ECU is GT or just the mapping? Because I have the JDM evo9 gsr also and the ROM ID is 88570008.
You have PM.
You have PM.
did you check the knock filters in the GT rom to see if it matched the GSRs rom? that could be the factor, cause the thresh holds could be off, post your rom and i will take a look at it.
You have PM.
You have PM.
Here is the log and .xml file. i need ur email to send ROM, its too big to post!
paste the xml file here so u can open the rom in Ecuflash and PM me ur email
C:\Program Files\OpenECU\EcuFlash\rommetadata\mitsubishi\evo
Zip file:
Edit: If you send me your ROM, I can tweek it a bit to get it to stop knocking....
email is thomas dot klemann @ forceprotection dot net
check ur emails in 10 mins
it should be there..anyone else with feedback???
apparently my timing is all over the place, its not matching with what it is supposed to be in my rom....what can this mean???
u will see in the emails!
coultema@cvn75.navy.mil send me your rom
One thing I thought of also is the GSR and GT have different turbos also.
So you're using a ROM that's mapped for a different turbo than the one you have.
edit: Nevermind I just noticed you said you're running maps suited for your car
the only difference in turbos is they had an option for the titanium shaft and fins were as the RS's came stock with them and the GSR doesn't have them at all i think. looking at you rom it seems the def. is all fu%cked up, but that may be my computer. i looked at you timing and its really low in your rom and your fuel map looks normal at spool and then really rich, but your not even hitting really high load according to your log. i would put a stock JDM RS map on there and then see how it runs. i will check your filter settings here later and go over your rom again when i get a chance and i will get back to you.
The knock filters are correct
A JDM RS map runs more aggressive maps. The car logged 21 counts of knock on a GSR map, it will be even worse with the timing on an RS. It's a step in the wrong direction imo.
The rom might look messed up if you have a different evo9base definition to read the 89980000 rom.
