evoscan incorrect dtc list air intake, engine coollant, presure sensor, knock sensor
Old Feb 24, 2008 | 11:54 AM
marklones's Avatar
hi people im new to this kind of fault diognosis but i find it hard to belive that i have the following errors on my car as they come and go each time i look at the dtc list
air intake
engine coolant
vehicle speed sensor
barometric sensor
knock sensor
fuel pump relay
but if i interrogate the sensors they look to be displaying the correct values as best as i can make out any way for example the engine coolant starts low and as the car heats up rises steadly
any help much appreciated
mark
Old Feb 24, 2008 | 12:57 PM
tephra's Avatar
what does scantech say?
Old Feb 25, 2008 | 02:23 AM
marklones's Avatar
sorry i dont know what scantech is
Old Feb 25, 2008 | 03:43 AM
tephra's Avatar
aktivematrix.com download scantech and run it
its a generic code puller. one of the others will help you choose the connection settings
Old Feb 25, 2008 | 04:53 AM
evo828's Avatar
mark - I used to have the same when I tried the check fault codes in Evoscan when the engine was running. Switch the engine off but let the ignition on - see what comes then.
No fault codes have been shown on scantech - so I assumed it is just going crazy when you run check faults when engine is running.
Old Feb 25, 2008 | 04:55 AM
bigric09's Avatar
i have tried this function a million times with the car running and it always returns some crazy faults.... i have yet to try it with the car off but the key in the on position. I just chalk it up to a function that doesnt work and i use my scan tool
Old Feb 25, 2008 | 08:24 AM
marklones's Avatar
i have downloaded scantech but i cant get it to work with the car (mitsubushi space waggon) or my lead that i brought from evoscan websits, OpenPort 1.3U Cable
i have emailed evoscan if i get a response i will let you all know
MitsuSkot
Apr 9, 2016 05:39 PM
Skyzo
Oct 17, 2012 06:39 AM
AlwaysinBoost
15
Nov 5, 2011 10:45 AM
jk_addict
37
Feb 27, 2009 12:23 AM
BadazzCR
Aug 23, 2008 07:40 AM
