Knock Help PLEASE
Old Mar 4, 2008 | 07:02 AM
bnice01's Avatar
Originally Posted by burgers22
x3 what TTP said, 21 deg at 130 load, 2500 is far to much, should be about half that. Have you reset your ECU in any way between low knock and high knock?
MB
I know right I run 1200cc of 100% meth and my timing is no way near that advance in the early cells (140-180).
Old Mar 4, 2008 | 07:04 AM
TTP Engineering's Avatar
Originally Posted by boldtx
Alright guys I had my knock count down to 1 to 2 and over night it seems it went back up to almost 10. My tuner suggested getting t bolt clamps to replace the cheap band ones that I had. He suspects that I have a boost leak. Unfortunately even after the new clamps she is still getting way too much knock. I still have yet to do a leak test but unless there is so odd ball place where the car could be leaking I am doubting that it is from the hoses. They are nice and tight now. Any help will be greatly appreciated I am at a loss.
We received your email and responded.
Old Mar 4, 2008 | 08:12 AM
C6C6CH3vo's Avatar
What will boost leaking have to do with knock?
Like it was mentioned above, too much spark advance, set the map to the timing the ecu pulled it to in order to stabilize increasing counts, but it looks like your on the right track now anyways
Old Mar 4, 2008 | 08:59 AM
bnice01's Avatar
email ya back.
timing was too high in certain shared load cells. fuel map needs some work, but I can fix that if you want.
Old Mar 4, 2008 | 09:23 AM
EVO8emUp's Avatar
Wouldn't a boost leak cause it to run richer?
Old Mar 4, 2008 | 11:15 AM
JohnBradley's Avatar
That timing map looks very specific to one tuner. I wonder how his timing maps look for Porsche and 335i's if thats how something other than his baseflash looks.
Old Mar 4, 2008 | 11:49 AM
I didnt think vishnu did eflashes.
Old Mar 7, 2008 | 06:00 AM
boldtx's Avatar
TTP Emails sent
