Request ID: Open/Closed Loop?
Old Mar 11, 2008 | 09:29 AM
DCsleeper's Avatar
Question Request ID: Open/Closed Loop?
Anyone know if there is a request id that logs whether or not you are in closed loop verses open loop?
I am trying to solve some low load knock issues and if I could log open vs. closed loop it may aid in solving my problems.
I am using mitsulogger at the moment to log.
Old Mar 11, 2008 | 09:35 AM
roger smith's Avatar
In your logs you can see when you go to open-loop by looking for where your o2feedback trim goes to 0.
Old Mar 11, 2008 | 10:17 AM
l2r99gst's Avatar
There is a requestID or a way to log it at least, but I don't know the requestID or variable to log. One of the disassembly guys can probably tell you.
Otherwise, just use the method mentioned above.
Eric
Old Mar 11, 2008 | 12:38 PM
DCsleeper's Avatar
Thanks Roger Smith. Never thought to look at that.
Old Dec 22, 2008 | 03:08 AM
acamus's Avatar
From: Lattitude 48.38°, Longitude 17.58°, Altitude 146m = Slovakia, for common dude
If I understand it correctly it is MUT_18
bit 0 = open loop due to acceleration?
bit 1 = open loop due to engine load or fuel cut due to decceleration
bit 2 .... bit 14 unknown - I am working on it
bit 15 - closed loop
Old Dec 22, 2008 | 03:48 AM
tephra's Avatar
^ bit15? on a byte???
Old Dec 22, 2008 | 04:00 AM
acamus's Avatar
Seems to be word
In 88590015
Code:
00016482                 bsr     sub 16728 (IS_CLOSED_LOOP_ENABLED)
00016484                 nop
00016486                 extu.w  r0, r0
00016488                 cmp/eq  #0, r0
0001648A                 bt      1649A
0001648C                 mov.l   @(h'90,pc), r10 ; FFFF6BEC (Open_Loop_Bit_Array)
0001648E                 mov.w   @r10, r0
00016490                 mov.w   @(h'88,pc), r11 ; h'1000
00016492                 or      r11, r0
00016494                 mov.w   r0, @r10
00016496                 bra     164A4
00016498                 nop
0001649A                 mov.l   @(h'84,pc), r10 ; FFFF6BEC (Open_Loop_Bit_Array)
0001649C                 mov.w   @r10, r0
0001649E                 mov.l   @(h'84,pc), r11 ; h'EFFF
000164A0                 and     r11, r0
000164A2                 mov.w   r0, @r10
Old Dec 22, 2008 | 04:13 AM
tephra's Avatar
oh no doubt its a word
I was just saying MUT18 is either the high byte or the low byte hehe
Old Dec 22, 2008 | 04:24 AM
acamus's Avatar
We will probably see one byte with MUT_18, but variable is word that is associated with that MUT request.
5LEEPERISAH23I
Mar 7, 2016 12:04 PM
rovanpera
Mar 5, 2011 04:40 PM
ezzey
AEM EMS
Oct 26, 2010 12:47 PM
johnnyr55
Apr 12, 2008 06:54 PM
Mad_SB
Jul 13, 2006 05:18 PM
