post your timing/afr maps:
Old Mar 12, 2008 | 03:41 AM
20Grockit's Avatar
hey guys i just recently started tuning. i am gonna post up my timing/afr maps later today when i get home from work. i have an evo 8 and mods are in my sig. the cams arent in yet. i just want to kind of compare to some of the others maps so i can kinda see where i stand. if any of you could help me out it would greatly be appreciated. if youre willing to help me edit my map there may be some $$ involved. lmk thanks.
Old Mar 12, 2008 | 06:31 AM
TeStUdO's Avatar
https://www.evolutionm.net/forums/sh...d.php?t=308720
This thread has plenty of timing maps. I'm sure you can find a similar one to your setup. As for the A/F map, start with a stock one and try to keep the same map progression. It's a decent starting point for you.
Old Mar 13, 2008 | 04:14 AM
20Grockit's Avatar
ok i did some adjustments and made some progress. i have 2 small questions, how can you tell if youre running too much timing?? how do the numbers in the knock sensor filter map equal counts of knock?? like how many units equals one count of knock??
Old Mar 13, 2008 | 04:16 AM
20Grockit's Avatar
testudo i looked in that thread and most of those maps are on evo 9's. the only evo 8 one i saw had cams and meth installed. his map would be alot different from mine.
Old Mar 13, 2008 | 04:40 AM
sharkm87's Avatar
you dont want to touch any of the knock settings, its the ecu that will look at that jargan and interpret it into knock count.
do you have all the necessary gauges for tuning?
Old Mar 13, 2008 | 05:01 AM
20Grockit's Avatar
ive got boost, egt, wideband, and oil pressure.
Old Mar 13, 2008 | 05:02 AM
20Grockit's Avatar
im about to remove the egt though since theres not really any need for it now that i have the wb
Old Mar 13, 2008 | 05:12 AM
TeStUdO's Avatar
EGT is still a good gauge to have. As for timing look in the "knock sum" column. Once you start getting knock, dial back the timing map 1 degree.
Old Mar 13, 2008 | 10:46 AM
sharkm87's Avatar
egt is also good for high boost applications, where you dont want to run too lean....just a secondary way of seeing whats goin on aside from the WB.
but it sounds as if you got all the necessary gauges, get out there and get logging....instead of comparing, post up yours and i'm sure people will chime in with advice.
Old Mar 13, 2008 | 11:36 AM
20Grockit's Avatar
ok man. thanks. as i mentioned im new to tuning an evo. ive tuned mazdas, vws and hondas before. this is the first time tuning an evo for me though. i tuned it before with an afc. ive built a few dsms in the past though. i built my buddy's car and it ran a best of 10.8 in a 1st gen. not too bad. im running 24psi on pump gas. i wanna run around 32-33 on race gas. ive pretty much got all the supporting mods. i have cams but just havent installed them yet. i wanted to see what i could achieve with the setup now before i drop in the cams. im gonna post up my timing/afr maps tonight when i get home. thanks for the advice man.
Old Mar 13, 2008 | 11:37 AM
20Grockit's Avatar
what temp. on the egt would be considered too lean??
Old Mar 13, 2008 | 11:41 PM
codgi's Avatar
You have a wideband so its better to use that to determine lean/rich than EGTs.
Old Mar 14, 2008 | 04:57 AM
20Grockit's Avatar
ok. i have a little problem. i was doing some logs last night and the car pulled hard as hell up to just over 5500. probably up to 5700rpms and then it cut out. almost like it missed. im gonna post up my timing and afr maps here in a minute so you guys can help me out. it also threw 2 codes when it happened. one is just an egr hose blown off. the other says its my vehicle speed sensor.
Old Mar 14, 2008 | 05:28 AM
20Grockit's Avatar
hey how are you guys posting the maps up?? i cant figure out how to paste it to here.
Old Mar 14, 2008 | 05:30 AM
tkklemann's Avatar
Agreed. The EGT gage in my car is my last resort "Oh **** something is really wrong and I am about to have to buy a shortblock soon" gage.
