Biggie Boost on 91 oct
As well as test pipe.
The most important things in my opinion to running big boost on pump gas are a very efficient IC and the least amount of backpressure as possible. His mods are setup very well for both of these conditions.
This most likely wouldn't be possible with the stock turbo, stock intercooler, and a cat. Just thought I would throw that out there just in case a few people start turning up their boost without monitoring knock levels.
Bryan, you are supposed to be testing 96530006, not turning up your boost. Get to work.
Eric
Eric
I also wouldn't think of doing this without tephra's knock CEL mod either so I can keep my eye on knock count.
As far as my cam gears, to be honest I can't even remember where I last set them at. I'll check and report back.
I had done a bunch of "logging" type pulls as well. I'm running approx 1-2* at 3750-4000rpm.
I had my car tuned for 24psi on 91... my tuner did a great job.
Everyone feels the car is extremely strong.
tbe, MBC, FP, and tune... no track numbers yet... I dont go to the drag strip much.
Also I think a IC and some sort of intake would help as we warm up in the spring in my case?
