Biggie Boost on 91 oct
Old Mar 18, 2008 | 04:09 PM
  #31
RazorLab's Avatar
Originally Posted by grenade
What kind of timing are you running at peak boost, tq, and total ? If you dont mind me askin..!
I'm using an interesting strategy with the timing curve / boost curve and AFR.
I'd like to keep it on my side for now.
That said, I highly doubt I could do this with a MBC. The ecu-boost control so far as been very vital to this.
Old Mar 18, 2008 | 04:34 PM
  #32
grenade's Avatar
Bummer, I figured as much. What about running on wastegate boost only as I am ??
Old Mar 18, 2008 | 07:44 PM
  #33
RazorLab's Avatar
Went out again tonight to dial in some more boost but didn't get past the first pull. Ignition is breaking up.
I put some new Iridium temp 8 plugs in when I switched to 91 oct a couple months ago and now I remember I just put them in straight out of the box. I think the gap is at .028 or .029. Lil' too big for 26psi plus.
I left my tools and extra plugs at the shop so I will swap the plugs out tomorrow.
Old Mar 18, 2008 | 09:00 PM
  #34
Jim in Tucson's Avatar
Thanks for starting this thread, Razor. I'm very interested in your "research".
Meaning, I started at a higher rpm, and not at the usual 2750 rpm or so.
I thought a logging pull should be started at a much lower RPM. Do you always log from 2,750 and up?
Old Mar 18, 2008 | 09:23 PM
  #35
RazorLab's Avatar
For full sweeps I start at 2500 or so.
Keep in mind the car loads a little differently with a pull from 2500, and a pull from 3500, etc etc
I do alot of different starting points to establish good data. For setting boost, it's very important so you don't get overshoots from different RPM start points. Reason is the boost ramps up much quicker in higher RPM than lower RPM.
You could have the boost control dialed in from a 2500 RPM sweep, then get on the hwy, downshift into 3rd from 4th and overshoot.
Old Mar 18, 2008 | 09:24 PM
  #36
Wicked E's Avatar
Razor-
How far are you from Vegas?
Cheers-
Erich
Old Mar 18, 2008 | 09:34 PM
  #37
RazorLab's Avatar
Originally Posted by Wicked E
Razor-
Cheers-
Erich
557 miles according to google maps.
http://maps.google.com/maps?f=d&hl=e...84&ie=UTF8&z=7
Old Mar 18, 2008 | 10:00 PM
  #38
Wicked E's Avatar
I'm wondering if i can get you to get my ecu boost control "tuned". Would really like to get everything from you to hook my stock solenoid back up.
Old Mar 20, 2008 | 07:26 PM
  #39
RazorLab's Avatar
Changed my plugs and re-installed my open filter at the shop today. Did a couple quick pulls on the way home. 26.5 psi with no spark plug break up and no knock, still on 91 octane.
This weekend I will get some more logs with data.
Old Mar 20, 2008 | 07:35 PM
  #40
eponti's Avatar
^Are you from lake tahoe area?
  #41
RazorLab's Avatar
Alameda. Right by Oakland. About as sea level as you can get.
Old Mar 20, 2008 | 10:14 PM
  #42
taenaive's Avatar
now, I am convinced that I can run 87 in my car with no knock.
Old Mar 21, 2008 | 06:19 AM
  #43
bnice01's Avatar
good stuff razorlab, ecu boost +1 again
some guys thought I was crazy tuning a evo8 for 25 psi on 93 octane but 91 good show man.
Old Mar 21, 2008 | 11:40 AM
  #44
JohnBradley's Avatar
26.5 on 91...PSSHHT I run 29 on 92...hahaha just kidding....Awesome stuff Bryan. We should compare notes, you want me to send you my ROM for a peek?
Old Mar 21, 2008 | 11:42 AM
  #45
Erik@MIL.SPEC's Avatar
Hasn't Scot Grey been running an 87 tune on his Eclipse for, like, forever?
