Let's see your customized EvoScan Data.xml
Old Mar 29, 2008 | 12:00 AM
recompile's Avatar
I figure there'd be some interest in what everyone's logging and in what order. I'm sure plenty of people out there have their own custom little calculations in EvoScan, so perhaps we can get a thread goin.
Mine's not too fancy:
Code:
<Mode2 name="Mode2" type="Data List Items">
	<DataListItem DataLog="Y" Color="" Display="2 Byte RPM" LogReference="2ByteRPM" RequestID="02" RequestID2="03" Eval="1000*x/256" Unit="RPM" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor="0.1" Notes=""/>
	<DataListItem DataLog="Y" Color="" Display="2 Byte Load" LogReference="2ByteLoad" RequestID="00" RequestID2="01" Eval="0.3125x" Unit="units" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="500" ChartMin="0" ChartMax="500" ScalingFactor="1" Notes=""/>
	<DataListItem DataLog="Y" Color="" Display="2 Byte Airflow" LogReference="2ByteAirflow" RequestID="04" RequestID2="05" Eval="6.29x/64" Unit="Hz" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="3200" ChartMin="0" ChartMax="3200" ScalingFactor="0.1" Notes=""/>
	<DataListItem DataLog="Y" Color="#F78284" Display="Timing Advance" LogReference="TimingAdv" RequestID="06" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="50" ChartMin="0" ChartMax="50" ScalingFactor="1" Notes=""/>
	<DataListItem DataLog="N" Color="" Display="Wideband A/F Ratio" LogReference="WideBandAF" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="60" ChartMin="0" ChartMax="60" ScalingFactor="10" Notes=""/>
	<DataListItem DataLog="Y" Color="#C000FF" Display="Knock Sum" LogReference="KnockSum" RequestID="26" Eval="x" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="50" ChartMin="0" ChartMax="50" ScalingFactor="10" Notes=""/>
	<DataListItem DataLog="Y" Color="" Display="JDM MAP" LogReference="JDMMAP" RequestID="38" Eval="0.19347*x-14.51025" Unit="psig" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-15" GaugeMax="30" ChartMin="-15" ChartMax="30" ScalingFactor="1" Notes=""/>
	<DataListItem DataLog="Y" Display="WGDC" LogReference="WGDC" RequestID="86" Eval="x/2" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100"/>
	<DataListItem DataLog="Y" Color="" Display="Load Error" LogReference="LoadError" RequestID="8A" Eval="0.15625*x-20" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-25" GaugeMax="25" ChartMin="-25" ChartMax="25" ScalingFactor="1" Notes=""/>
	<DataListItem DataLog="Y" Color="" Display="Boost Error" LogReference="BoostError" RequestID="8A" Eval="0.0241*x-3.087" Unit="psi" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-5" GaugeMax="5" ChartMin="-5" ChartMax="5" ScalingFactor="1" Notes=""/>
	<DataListItem DataLog="Y" Color="#B00009" Display="Throttle Position" LogReference="TPS" RequestID="17" Eval="100x/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes=""/>
	<DataListItem DataLog="Y" Color="#00AB39" Display="Injector Pulse Width" LogReference="InjPulseWidth" RequestID="29" Eval="0.256x" Unit="ms" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="66" ChartMin="0" ChartMax="66" ScalingFactor="10" Notes=""/>
	<DataListItem DataLog="Y" Color="" Display="Injector Duty Cycle" LogReference="IDC%" RequestID="02" Eval="([InjPulseWidth]*[2ByteRPM])/1200" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" Notes="([InjPulseWidth]*[RPM])/1200"/>
	<DataListItem DataLog="N" Color="" Display="Octane Level" LogReference="OctaneFlag" RequestID="27" Eval="100x/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes=""/>
	<DataListItem DataLog="Y" Color="" Display="Lbs/min" LogReference="LbsMin" RequestID="00" Eval="([2ByteLoad]/95*[2ByteRPM])/454" Unit="lbs" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="65" ChartMin="0" ChartMax="65" ScalingFactor="1" Notes=""/>
	<DataListItem DataLog="Y" Color="#FFAD00" Display="Speed" LogReference="Speed" RequestID="2F" Eval="1.2427424x" Unit="Mph" MetricEval="2x" MetricUnit="Kph" ResponseBytes="1" GaugeMin="0" GaugeMax="280" ChartMin="0" ChartMax="280" ScalingFactor="1" Notes="Not loggable on some Mitsubishis"/>
	<DataListItem DataLog="Y" Color="#57E835" Display="Coolant Temp" LogReference="CoolantTemp" RequestID="07" Eval="-0.0003893xxx+0.08056xx-6.5226x+315.73" Unit="deg F" MetricEval="((-0.0003893xxx+0.08056xx-6.5226x+315.73)-32)/1.8" MetricUnit="deg C" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes=""/>
	<DataListItem DataLog="Y" Color="" Display="Air Temperature" LogReference="AirTemp" RequestID="3A" Eval="-0.00000001300xxxxx+0.000006657xxxx-0.001341xxx+0.1353xx-7.874x+336.1" Unit="deg F" MetricEval="((-0.00000001300xxxxx+0.000006657xxxx-0.001341xxx+0.1353xx-7.874x+336.1)-32)/1.8" MetricUnit="deg C" ResponseBytes="1" GaugeMin="0" GaugeMax="255" ChartMin="0" ChartMax="255" ScalingFactor="1" Notes=""/>
</Mode2>
Old Mar 29, 2008 | 09:33 AM
codgi's Avatar
Man you always want to see other people's stuff . First timing maps, then dataxml, whats next?
Above is similiar to mine...only difference being that I didn't remove the other stuff I don't log. I just left in in unchecked.
Old Mar 29, 2008 | 09:44 AM
inco9nito99's Avatar
Like the idea...makes it widely known and helps a lot of ppl.
Old Mar 29, 2008 | 02:33 PM
tkklemann's Avatar
ZZZZiiiiiiiipppppppppp............ Flop......
Old Mar 29, 2008 | 02:37 PM
tkklemann's Avatar
Code:
        <DataListItem DataLog="Y" Color="#B00009" Display="Throttle Position" LogReference="TPS" RequestID="17" Eval="100*x/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="This is an indication of how much fun you are having, kind of like a fun gage" Priority="1" Visible="false" />
        <DataListItem DataLog="Y" Color="#fa903a" Display="Engine RPM" LogReference="RPM" RequestID="21" Eval="31.25*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="8" ChartMin="0" ChartMax="80" ScalingFactor="0.01" Notes="Oh **** honkey, it spinnin fo reelz! Dis is how fas it be spinnin, Yo." Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="RPM MUT 2Byte Mod" LogReference="RPMMUT2Byte" RequestID="02" RequestID2="03" Eval="1000*x/256" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="2500" ChartMin="0" ChartMax="8000" ScalingFactor="0.1" Notes="RPM MUT 2Byte Mod is a reflashed modification to see jus really how fas is be spinnin fo reelz" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Load MUT 2Byte Mod" LogReference="LoadMUT2Byte" RequestID="00" RequestID2="01" Eval="0.3125*x" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="345" ChartMin="0" ChartMax="500" ScalingFactor="1" Notes="Load MUT 2Byte Mod is a reflashed modification to the ECU to see if you is beating it like yo hoe when sh owe yous Benji's, or if you is only shakin da hoe, not beatin a bish" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="JDM MAP" LogReference="JDMMAP" RequestID="38" Eval="0.19347*x-14.897" Unit="psig" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="-15" GaugeMax="30" ChartMin="-15" ChartMax="30" ScalingFactor="1" Notes="BOOST BOOST BOOST WERDZ LIKE OMG LOL WTF Kthxbai" Priority="1" Visible="false" />
        <DataListItem DataLog="N" Color="" Display="External Wideband A/F Ratio" LogReference="WideBandAF" RequestID="WDB" Eval="x" Unit="a/f ratio" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="10" GaugeMax="16" ChartMin="10" ChartMax="16" ScalingFactor="10" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Airflow MUT 2Byte Mod" LogReference="AirFlowMUT2Byte" RequestID="04" RequestID2="05" Eval="6.29*x/64" Unit="Hz" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="3000" ChartMin="0" ChartMax="3000" ScalingFactor="1" Notes="Airflow MUT 2Byte Mod is a reflashed modification to the ECU to see accurately jus how much a hoe be a suckin" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="#F78284" Display="Timing Advance" LogReference="TimingAdv" RequestID="06" Eval="x-20" Unit="deg" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="45" ChartMin="0" ChartMax="50" ScalingFactor="1" Notes="" Priority="1" Visible="false" />
        <DataListItem DataLog="N" Color="#C000FF" Display="Knock Sum" LogReference="KnockSum" RequestID="26" Eval="x" Unit="count" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="40" ChartMin="0" ChartMax="50" ScalingFactor="10" Notes="This is how gay your tune is." Priority="1" Visible="false" />
        <DataListItem DataLog="N" Color="#ffad00" Display="Speed" LogReference="Speed" RequestID="2F" Eval="1.2427424*x" Unit="Mph" MetricEval="2*x" MetricUnit="Kph" ResponseBytes="1" GaugeMin="0" GaugeMax="280" ChartMin="0" ChartMax="280" ScalingFactor="1" Notes="This is how fast you are not getting your car to go." Priority="1" Visible="False" />
        <DataListItem DataLog="Y" Color="" Display="Battery Level" LogReference="Battery" RequestID="14" Eval="0.07333*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="16" ChartMin="0" ChartMax="16" Notes="This is how much zap a hoe powerz your battery be havin" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Airflow/Rev" LogReference="AccelEnrich" RequestID="1D" Eval="200*x/255" Unit="load" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="300" ChartMin="0" ChartMax="300" ScalingFactor="1" Notes="" Priority="1" Visible="false" />
        <DataListItem DataLog="N" Color="" Display="Coolant Temp" LogReference="CoolantTemp" RequestID="10" Eval="1.8*x-40" Unit="deg F" MetricEval="x-40" MetricUnit="deg C" ResponseBytes="1" GaugeMin="-40" GaugeMax="260" ChartMin="-40" ChartMax="260" ScalingFactor="1" Notes="This is how hotz it be up in dis joint. If it get too hot up in her, get yo *** outta da kitchen" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Air Temperature" LogReference="AirTemp" RequestID="11" Eval="1.8*x-40" Unit="deg F" MetricEval="x-40" MetricUnit="deg C" ResponseBytes="1" GaugeMin="-40" GaugeMax="260" ChartMin="-40" ChartMax="260" ScalingFactor="1" Notes="Temp of air sucked in by yer hoe to be squished, banged, and blowed out" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Octane Level" LogReference="OctaneFlag" RequestID="27" Eval="100*x/255" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="100" ChartMin="0" ChartMax="100" ScalingFactor="1" Notes="If this number is less than 100, you suck at tuning" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Air Flow Hz" LogReference="AirFlow" RequestID="1A" Eval="6.25*x" Unit="Hz" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="1650" ChartMin="0" ChartMax="1650" ScalingFactor="0.1" Notes="The rate of flow of air into the engine. Some ECUs report air flow voltage, whilst others report a calculated flow rate. The voltage from which the ecu calculates mass air flow is non-linear, with smaller changes in output voltage being seen for flow changes at high rates compared with low flow rates. It is from mass air flow that the ECU calculates engine load which has a big influence on ignition timing and fuelling. &#xD;&#xA;&#xD;&#xA;" Priority="1" Visible="false" />
        <DataListItem DataLog="N" Color="" Display="Barometer" LogReference="Baro" RequestID="15" Eval="0.49*x" Unit="kPa" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="126" ChartMin="0" ChartMax="126" ScalingFactor="1" Notes="Dis is how much presshure is bein put on ya hoez" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Target Idle RPM" LogReference="TargetIdleRPM" RequestID="24" Eval="7.8*x" Unit="rpm" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="8000" ChartMin="0" ChartMax="8000" ScalingFactor="0.1" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Fuel Trim Low (LTFT)" LogReference="FuelTrim_Low" RequestID="0C" Eval="(0.1961*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="200" ChartMin="0" ChartMax="200" ScalingFactor="1" Notes="Long Term Fuel Trim - Low" Priority="1" Visible="false" />
        <DataListItem DataLog="N" Color="" Display="Fuel Trim Mid (LTFT)" LogReference="FuelTrim_Mid" RequestID="0D" Eval="(0.1961*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="200" ChartMin="0" ChartMax="200" ScalingFactor="1" Notes="Long Term Fuel Trim - Mid" Priority="1" Visible="false" />
        <DataListItem DataLog="N" Color="" Display="Fuel Trim High (LTFT)" LogReference="FuelTrim_High" RequestID="0E" Eval="(0.1961*x)-25" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="200" ChartMin="0" ChartMax="200" ScalingFactor="1" Notes="Long Term Fuel Trim - High" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Oxygen Feedback Trim (STFT)" LogReference="O2FeedbackTrim" RequestID="0F" Eval="0.78125*x" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="200" ChartMin="0" ChartMax="200" ScalingFactor="1" Notes="Short Term Fuel Trim - When the fuelling is under closed loop control by the lambda sensor(s), this refers to the amount of fuel added or subtracted from the value retrieved from the fuel map. -5% would mean that the ecu is fuelling 5% less than the map says in order to achieve the ideal air/fuel ratio. Under high loads, the ECU switches off closed loop control, and uses values from the map. At this point, you will see AFC drop to 0%. This is why it is important that fuelling mapping is accurate (or at least rich) at high loads - the ECU does not compensate for errors here. " Priority="1" Visible="false" />
        <DataListItem DataLog="N" Color="#EFE600" Display="Oxygen Sensor" LogReference="O2Sensor" RequestID="13" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="5" ChartMin="0" ChartMax="5" ScalingFactor="100" Notes="" Priority="1" Visible="false" />
        <DataListItem DataLog="N" Color="" Display="Oxygen Sensor #2" LogReference="O2Sensor2" RequestID="3C" Eval="0.01952*x" Unit="V" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="5" ChartMin="0" ChartMax="5" ScalingFactor="100" Notes="" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="#00ab39" Display="Injector Pulse Width" LogReference="InjPulseWidth" RequestID="29" Eval="0.256*x" Unit="ms" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="66" ChartMin="0" ChartMax="66" ScalingFactor="10" Notes="Dis is how long yo bish be spittin the juicy out" Priority="1" Visible="False" />
        <DataListItem DataLog="N" Color="" Display="Injector Duty %" LogReference="InjDutyCycle" RequestID="21" Eval="[InjPulseWidth]*[RPMMUT2Byte]/1200" Unit="%" MetricEval="" MetricUnit="" ResponseBytes="1" GaugeMin="0" GaugeMax="160" ChartMin="0" ChartMax="160" ScalingFactor="1" Notes="Dis is how much juicy yo bish be spittin out" Priority="1" Visible="False" />
      </Mode2>
Please, Ignore the ebonics...
Old Mar 29, 2008 | 02:56 PM
JohnBradley's Avatar
When I get off of work and get home. Shameless I like how you condensed the Lbs/min routine...I wish I had thought of that.
Old Mar 30, 2008 | 01:50 AM
recompile's Avatar
It makes it easier to look at logs when you don't have so many empty columns.
I used to make Excel macros to hide unused columns and auto filter by TPS > 90, but when I change around what I log and what car I log, the macro's don't always apply, so this makes it much easier.
I just removed the stuff I don't use and made data.xml.removed so I can always add it back in.
Old Apr 1, 2008 | 10:45 AM
recompile's Avatar
JB, where are yours at!?
Old Apr 1, 2008 | 12:07 PM
Sorry man...let things get in the way. A couple of quick notes. I like to rename things so some of what you are going to see is 2 byte but it might not say that:
I also have redone a few of the MUT requests so this data.xml will not work for everyone though it will show whats going on I think.
This is also V99...I do not use anything newer for a few reasons. The GUI isnt really much different and I dont need to edit the xml from Evoscan since V99 is really pretty much setup. If I add anything its just as easy to add it to the .xml with wordpad for me. Also since everyone else has problems with maptracer, and I have been using excel for so long that part doesnt really excite me. I will end up getting 2.1 probably though, just for the STi stuff.
File Type: zip
Old Apr 1, 2008 | 12:18 PM
Like the MIVEC/Alternator features you added/changed JB.
Old Apr 1, 2008 | 12:36 PM
recompile's Avatar
Cool. Does logging MIVEC require any changes to the MUT table ?
Old Apr 1, 2008 | 02:35 PM
Well yes and no. You need to add the values of 7650 and 7651 to an open MUT location..I think I used 40 and 41 as per Tephra's orginal instructions (all the 4x are unused addys) and then make sure that those MUT addys are the same as request ID1 and 2.
Other than that you are good to go.
MIVEC was courtesy of mrfred, and I dont like looking at the "battery" label when its not the battery its the stinking alt..
Old Apr 1, 2008 | 02:37 PM
Also while I am thinking of it, about the timing...the 3 of them and some of the other stuff as well...
Timing Advance is what the car runs
Timing Alpha appears to be what the positive modifiers want to add (not counting knock, which would be a negative modifier). I have this as a total value but you could change the xml to subtract Beta to see what the total change is. I could, I am just lazy and dont care enough since I compare them all side by side.
Timing Beta appears to be what the map actually physically says for that rpm/load.
G/rev I keep seperate though Cookie put it together (I do like that btw) because since I also do subarus I can compare and see where a subaru is for the amount of g/rev (in their case they dont use "load" just g/rev) and lbs per min to hp against a known quantity like an Evo. I can look at a nearly stock Sti and see it hit 3.25 g/rev at low boost where you have to flog an Evo to do the same thing but the Evo still makes more power. Not anti-sube, just one more piece of the puzzle I am trying to figure out.
Old Apr 2, 2008 | 11:43 AM
lemmonhead's Avatar
wait your able to log mivec in evoscan now? thats something I wanna do for sure.
Old Apr 2, 2008 | 10:59 PM
codgi's Avatar
Thats exactly why I didn't remove those from the xml. The columns stay constant regardless of car.
Hiram6g74
Apr 13, 2017 08:59 PM
GST Motorsports
113
Feb 14, 2017 06:09 AM
tephra
31
Jun 26, 2014 12:54 PM
RngrYogi
Jun 3, 2013 01:45 AM
acamus
Oct 14, 2008 11:55 AM
