Is my AFR ok? few new mods evo IX
Old Apr 9, 2008 | 02:23 PM
xpro's Avatar
hi,
can someone please tell me if my afr looks ok? i attached 4th gear pull,but only went up to 6k,wasnt sure if the car is running ok.it is an FQ340 with few mods.decat,k&n drop in and walbro pump.
And also when logging afrs,would logworks be better then evoscan?
im using lc-1
thanks,
Old Apr 9, 2008 | 02:42 PM
Mr. Evo IX's Avatar
To be sure you'll need to keep the pedal planted 100% TPS for the entire pull 2500-Redline (3rd gear is fine). However part throttle looks fine. Your 1 counts of knock are fine and can be ignored. Need a full pull to make a real assessment though.
It leans out a little at 4250 (13.4 during spoolup) but it could be because your part throttle. I'd personally like to see that more 12.5 ish but it may be lean there to help spool the turbo up as well.
DsmEvo87
Apr 20, 2016 10:18 PM
ms32evoixmr
May 25, 2015 02:21 AM
MivecAddict
Jul 25, 2011 08:20 AM
saiyuke
Aug 28, 2008 03:04 AM
bmojito
Jul 7, 2008 01:36 PM
