Need quick help on disabling patch for P0443
Old Apr 11, 2008 | 11:58 AM
9sec9's Avatar
I'm finishing the prep on OKIX's car and after re-installing the Intake Manifold, I'm getting the P0443 code and very rough idle. I could swear that I kept a printout of a disable value in the patches for Periphery4, but can't find it anywhere. I've searched for nearly an hour and can't find it in the threads. Could someone help me out. Thanks in advance.
Old Apr 11, 2008 | 12:32 PM
JohnBradley's Avatar
Tom, P0443 is Evap/egr?
If it is try periphery 2 (fca or fba...cant remember) and change the value from 0xefdf to 0x8d89. The connectors for everything need plugged in, but nothing actually has to be working.
Old Apr 11, 2008 | 12:35 PM
9sec9's Avatar
I've got Periphery2 set to EDDF, so you're saying that 8D89 on the 8859 version?
Wicked E's Avatar
What rom id?
Cheers-
E
Old Apr 11, 2008 | 12:37 PM
Wicked E's Avatar
Is this what you're talking about needing?
Code:
<table name="EGR MAP Offset #1" category="MAPSensor" address="4936" type="2D" level="1" scaling="uint8">
	<table name="RPM" address="74de" type="Y Axis" elements="9" scaling="RPM"/>
	</table>
	<table name="EGR MAP offset #2" category="MAPSensor" address="4946" type="2D" level="1" scaling="uint8">
	</table>
	<table name="EGR Pressure Diff" category="MAPSensor" address="1B7C" type="1D" level="1" scaling="Volts16"/
Cheers-
E
9sec9's Avatar
88590015
Old Apr 11, 2008 | 12:39 PM
9sec9's Avatar
it's the disable function to the Evap that give the P0443 cel code. I could swear I had it. JB, is the same Periphery used for both EGR and EVAP?
Old Apr 11, 2008 | 12:40 PM
Wicked E's Avatar
Perph 4 is set to B980
Perph 2 is set to EDDF (This disables Rear O2 I think)
Cheers-
E
Old Apr 11, 2008 | 12:42 PM
9sec9's Avatar
Cheers-
E
That's how I've had it set, but it just started throwing the P0443 code. Didn't do it at Shreveport races. Don't know why it just started, but I had the intake manifold off and maybe something got unplugged, I'll have to check that too I guess.
Old Apr 11, 2008 | 12:43 PM
Yeah from what I have been able to decode from Bez' orginal table and the JDM and EDM roms that dont have EGR/EVAP thats the value you want.
EDDF doesnt do the trick
8D89 or 89DF, Its the 89 part of the bit thats important.
I use 8d89 as does lucas and thats all off our cars
Old Apr 11, 2008 | 12:44 PM
9sec9's Avatar
To disable the egr test, periphery2 is changed from efdf to eddf based on MRfreds posts.
Periphery 4 is b980 for the 3 bar or f980 stock MDP
faa set to 56d8 turns off rear O2
Old Apr 11, 2008 | 12:45 PM
Wicked E's Avatar
Here you go buddy...
MrFred to the rescue
https://www.evolutionm.net/forums/sh...ight=egr+patch
9sec9's Avatar
Thanks a ton JB, I'll change it and let you know. I appreciate the quick responses and help.
Old Apr 11, 2008 | 12:46 PM
I just checked all my ROMS and found:
JDM is set at 8C89 or 8D89
EDM are set at 89DF
