Trouble with MAF
Old Apr 16, 2008 | 05:30 AM
Appauldd's Avatar
Trouble with MAF
For some odd reason my MAF will read great until about 3000 RPM then it goes flat at 200 all the way to redline.
Any ideas on how to make the MAF read more accuratly.
I have full HKS hard pipes and a Blitz FMIC. Also have a K&N cone filter.
Tell me what you experts need to see and I will post it up.
FWIW I have not scaled the MAF.
Thanks.
Paul
Old Apr 16, 2008 | 05:33 AM
Tuner@Swift's Avatar
Are you only reading 1 byte airflow?
Old Apr 16, 2008 | 06:51 PM
Appauldd's Avatar
I thought I upgraded the 2 Byte airflow mod. Maybe I did something wrong. It is frustrating me because I believe that the MAF is what is causing fuel cut at 5500 WOT.
Old Apr 16, 2008 | 06:54 PM
Has the stock boost limit been raised? If so, then its probably a spark blowout or if you have a walbro fuel pump the hose on the pump is loose.
Old Apr 16, 2008 | 06:58 PM
Appauldd's Avatar
I have a walbro 255 and correctly scaled 780cc injectors. The boost is set with a Buschur MBC to 21 lbs
What is really wierd is that if I use anything except full throttle the car pulls like a beast with no cut out.
senate6268
Lancer Engine Management / Tuning Forums
91
Dec 26, 2022 12:20 AM
4G63_EVO
Jul 14, 2017 02:24 PM
maxspeed96ct
Northeast Region
Aug 22, 2016 11:08 AM
top222
Northwest Region
Apr 17, 2012 12:07 PM
Done
Sep 11, 2008 05:09 PM
