Broke my wastegate solenoid boost line
Today while installing a modifed pill on the turbo and solenoid sides I broke (punch) the line that goes from the T to the wastegate solenoid (that is the small one). Can I get any line that is about the same size or do I need any special spec or the original one? Will any rubber line work? What about line expansion?
Is it worth upgrading the plastic T pipe with a brass one? Do the boost assemblies from GST comes with two pills one on the compressor and the other pill on the wastegate solenoid side or does it has just one on the compressor side?
I am tempted to go ahead with the GM 3 Port but that will take at least a week to get here. Also for stock turbo and pump gas I am not sure if it is worth over the stock one with modifed pills. I am chaging both the compressor side (using a slightly modifed GST, just made a conic area on both ends of the pill) and the wastegate solenoid pill, the solenoid side now is 0.078 mils (that about 0.018 bigger than stock).
The GST assembly has a upgraded pill in the factory location (compressor housing side) and the factory pill in the solenoid side. There is no pill, nor should there be on the wastegate actuator side.
