weird problems
Old Apr 21, 2008 | 01:56 AM
spdracr's Avatar
weird problems
basically i am getting a solid 9 counts of knock when ever i touch the gas. rev matching reving anything. i think its a bad knock sensor. i am checking the wiring today. also as soon as this happened my idle went nuts 1400rpms bouncing up and down doesnt make any sense. it all happened at once. i tried to answer all questions i percieved in my OP but i guess it was too confusing.
Old Apr 21, 2008 | 02:15 AM
tephra's Avatar
dude - can you edit that?
just make it a bit more readable
Old Apr 21, 2008 | 03:11 AM
I'm blue's Avatar
ok I understood some stuff and some just flew off my head.. how ever i do have a question for u do u have a light weight fly wheel i will explain later if yes and at all cases if u please rewrite the above again and identify the problem.
Old Apr 21, 2008 | 03:35 PM
spdracr's Avatar
no i dont have a lightweight flywheel and i do get the p0300 code issue as well i'll re write it tonight sorry i had been up for a while when i wrote that lol
Old Apr 21, 2008 | 03:53 PM
spdracr's Avatar
also i tried resetting the ecu, flashing stock map. nothing worked. weird.
Old Apr 21, 2008 | 04:02 PM
JohnBradley's Avatar
Start at the beginning.
What if anything have you changed recently.
Have you added parts that might be loose, or do you have old parts that might be worn out.
Old Apr 21, 2008 | 11:29 PM
spdracr's Avatar
i think the wiring on the knock sensor is jacked up because the day before i put it on some 102 octane and was messin around and the lead from the alternator broke off the little cirlce connector that screws on it. i had to fix that so i think that the knock sensor wiring is messed up in a similar way. other than that theory i got nothin. the auto hobby shop doesnt open here on base until wed. so i can put it on a lift then to double check underthe car.
one thing i did think about is the nut that holds the turbo to the manifold vibrated its way off. i had to replace them with extras i have laying around it might be possible that its sitting somewhere vibrating and makin the noise or something?
Old Apr 22, 2008 | 09:03 AM
C6C6CH3vo's Avatar
Any unusual noises? Clutch disengage same as before?
Old Apr 22, 2008 | 03:18 PM
spdracr's Avatar
there was always like a weird noise after a certain shop put in my TRE tranny like something was tapping the firewall but i could never locate the problem. and it never created an issue before. after i installed the torque dampner that noise pretty much went away. i just realized the my A/C does not work at all which is weird because it was fine not too long ago. could the A/C clutch have failed and all that stuff in there is messed up.
Old Apr 25, 2008 | 09:27 AM
spdracr's Avatar
well i just fixed the knock issue it turns out that the knock sensor wires were "cut" it looked like someone cut them with wire cutters right at the back of the connector thats on the main harness. i just took off the connectors and directly wired them. im still gettin really bad throttle hang probably from a dirty airfilter and maf sensor since they are really dirty but i also found the A/C connectors were cut in a similiar way to the knock sensor which explains why my a/c mysteriously stopped working. has anyone seen anything like this before?
4b11slayer
Nov 1, 2016 02:38 PM
jjayp
Mar 12, 2011 12:01 AM
LaXGSR
13
Oct 1, 2010 08:26 AM
jmoudry
Apr 18, 2007 08:00 PM
TrinaBabe
Oct 31, 2004 10:49 PM
