Evoscan IDC reading 0
Old Apr 22, 2008 | 02:39 PM
sponners's Avatar
Hiya chaps!
for some reason I can't get any readings for my IDC?
they're all reading 0
I'm logging on a jdm evo 6 (standard ecu) using evoscan 2.1
my IDC formula is [InjPulseWidth]*31.25*x/1200
my IPW formula is 0.256*x seems to be working ok.
anyone got any ideas?
Thanks guys
Mark.
Old Apr 24, 2008 | 05:31 AM
sponners's Avatar
anyone?
Old Apr 24, 2008 | 05:37 AM
recompile's Avatar
Make sure you're logging IDC after IPW so it can use the value in its calculations.
EvoScan's default IDC calculation is lame... I use:
LogReference="IDC%" RequestID="00" Eval="([InjPulseWidth]*[2ByteRPM])/1200"
You can use regular RPM (without the 2Byte prefix) and I bet it will fix this.
Old Apr 24, 2008 | 08:56 AM
bnice01's Avatar
how did you get it to work request ID 00 is 2byte load?
If you look thru the evoscan data.xml the Fuel Consumption, Gear, & IDC all request ID 21 no wonder why it doesnt work.
Old Apr 24, 2008 | 10:48 AM
nonschlont's Avatar
+1
Old Apr 24, 2008 | 11:13 AM
Tuner@Swift's Avatar
Request ID 21 is for RPM, which all the things you listed require to calculate.
Old Apr 24, 2008 | 12:52 PM
recompile's Avatar
It doesn't matter what RequestID you use because I'm not grabbing a value from the MUT table to calculate IDC (notice how there's no "x" in the Eval)
I'm just using IPW & RPM to perform a basic calculation. Another variation would be:
LogReference="IDC%" RequestID="21" Eval="([InjPulseWidth]*x)/1200"
Old Apr 24, 2008 | 02:11 PM
bnice01's Avatar
ahhhh gotcha thanks man
just rewrote some things in my data file, everything should be good now. I guess I didnt realize 21 was for rpm, I always use 2byte rpm.
Old Apr 25, 2008 | 11:57 AM
sponners's Avatar
thanks for the help guys! will try out
lexa609
Sep 25, 2016 02:34 PM
Chet3215
Jul 24, 2016 11:51 AM
PeteyTurbo
Jun 25, 2008 02:17 PM
racer135
May 17, 2008 02:00 AM
dudical26
Feb 17, 2008 05:09 PM
