Rescaling Your ECU for E85 - It's Easy
Old May 11, 2008 | 09:54 PM
  #31
dude's Avatar
Originally Posted by tkklemann
So, instead of creating a new thread, I thought I would post this here..
First off, everyone keeps talking about the correlation of E85 to Gasoline in terms of lambda on a Gasoline Calibrated wideband. Doesn't the Innovate LC-1 have a setting in it to where you can set it up for E85? What does this setting do? I looked in the LC-1 manual and it isn't really clear as to what changes when you change this from Gasoline to Ethanol.!
Yes you could change the calibration of the lc-1 to output ethanol lambda, but that just adds more confusion in my mind when tuning and comparing pump gas numbers.
Also, from what I gather, open loop fueling will not change from 14.7. WOT pulls though, once again, from what I gather, I will be targeting roughly around 11.7-11.8 on a gasoline calibrated wideband at WOT. What AFR's are agressive, semi-agressive, conservative, and just plain rich for E85?
Correct. I believe Lucas English has tuned several e85 cars to close to 13:1 gas lambda. I consider that agressive. Conservative would be anything richer than 10.5:1 gas lambda. My car is currently in the 11.5-11.8 range on e85 and gas lambda.
I have pre-set up a map, reduced my 1083 injector scaling to 760 (For a rough 30% decrease) and took my 135-350 load values (Based on my map scaling) and multiplied it all by 0.95. The 100-135 it interpolated to smooth the changed together, and changed my low octane to suit the high octange changes. Timing map I left alone as they are pretty dead nuts for my car at 27.5-28psi 11.5-11.7 afr running 93.
I think that you'll find your fueling maps only require slight tweaking but your timing maps will require the most tuning to really gain from the increased knock resistance (octane) of e85. You'd be surprised how much timing you can advance without knock on it, much like race gas.
My map scalings should be OK as I was hitting low 320's at peak torque on 93, and the maps are scaled to 350. Do you think 350 will be OK, or better yet, to the people who have switched to E85, how much higher loads were you hitting with timing/boost changes you made?
Hard to say. I was hitting 285 or so on 93. e85 saw load over 290. Adding a GM 3 port and upping boost I'm in the 310 load range. Still have more tuning to do, but I would dare say you are going to be pushing 350 after advancing ignition timing.
Hopefully some of you can chime in on this relatively quickly, as tomorrow after work, my tank will be very close to being empty, and as soon as work is done, I am going to put a full tank of E85 in her, and jump in face first. I just want to make sure all my logic and target values to go after are all in line.
Seems like initially I will just be waiting/watching for my fuel trims to start to go up, then reflash with my new map, and see if they level back out. Basically ust tweak the scalings to get the trims as close as I can, them possibly make a few tweaks to the latencies. Once that's done, start to do roll on's to see what the car is doing under higher and higher loads, then go all out with a WOT 3rd gear.
All sound OK? Please add input/advice tips!
Correct. If your fuel trims were right on with pump gas, you should only have to make minor corrections to get your e85 trims in line. From there, crank the boost and then start enjoying how much more aggressive you can get with the corn. Hit me up if I can be of any other help or share my maps with you.
Old May 11, 2008 | 10:12 PM
  #32
scheides's Avatar
EvoM Moderator
Another question, did you guys have to re-gap the spark plugs? I've heard you have to run .019" or something crazy on the stock ignition?
Old May 11, 2008 | 10:19 PM
  #33
dude's Avatar
Nope. Running NGK copper BR8ES gapped at .024 with no break up at all at 29psi.
Old May 12, 2008 | 06:01 AM
  #34
JoeBee's Avatar
Question to the E85 cracks. (Sorry for the double post, but maybe more people find it here)
This morning I need to crank my car 4 times to start with E85.
Which parameters in ecuflash can be changed to help the starting?
Old May 12, 2008 | 06:35 AM
  #35
l2r99gst's Avatar
I haven't switched to E-85 yet, but I don't think anyone has found the answer to this question yet.
I remember posts asking about cranking ignition tables or routines during cranking, but I don't think anything was found, at least that I remember.
Have you tried logging while cranking to see what voltage, ignition, etc is being used? I'd be curious to see the voltage during cranking. Maybe a lower voltage is present and one of the lower latency values can be increased to just increase the fueling during cranking? Maybe there are completely different fueling/ignition for cranking?
I'm interested in this answer as well, since I plan on switching to E-85 this summer maybe and I want to avoid the hard starting in the winter as much as possible.
Eric
Old May 12, 2008 | 01:10 PM
  #36
Jorge T's Avatar
What works to help a lean start is to raise the min temp for closed loop 40-45*C and enrichening the fuel map in the 500-1500 rpm / 20-40 load range
Old May 13, 2008 | 02:15 AM
  #37
JoeBee's Avatar
Thanks a lot. I will try this soon.
Another tip (from a german forum, thanks to gpunkt) was to fake the Water Temp Sensor signal to tell the ECU it is dammed cold out there.
Press a button like a choke in classic cars.
Old May 13, 2008 | 02:32 AM
  #38
tephra's Avatar
Ted I would love to see the first post updated with a bit of a howto and any new info you have on the subject.
be a good resource for us unleaded ppl
what injector size is recommended for stock turbo?
Old May 13, 2008 | 03:44 AM
  #39
tkklemann's Avatar
So, I made the switch last night! Woo Woo!
And holy crap, you can really tell by the smell when the E85 hits.. Yipes, can't hide that from anyone... Especially with no cat...
OK, here is the process I did, and it was more than successful:
I let the tank get as low as I dared go on the way to the gas station. When I filled it up, the tank took in 13.74 gallons, so there was about 1/4 gallon, plus whatever was in the fuel lines and rail to "get rid of". I filled up and drove to the other side of the gas station, and simply sat in the car with it idling. I flashed the car prior to starting to have the idle with the A/C on at 1500rpm, just to speed up the process. It took probably 5-7 minutes for the car to all the sudden start running lean, and stumble. You could definately tell when the E85 hit the fuel rail, and started to go through the motor.
I let it run, stumbling around for about 2 minutes, then turned the car off and reflashed it for my "general" 30% injector re-scaling number. I went from 1083 scaling for FIC 1050's to 750, and it made the fuel trims sit at 2.846 Low and 5.7877 Mid after about 15 minutes of driving. This morning however, I changed the scaling to 731 to see if I can get it on the slightly negative side, and it's still changing and adjusting itself. Currently as of 5:30 this morning, it sits at 2.6501 Low and 4.415 High.
To those of you guys that haven't made the switch, definately do it. It's very forgiving, and it's really apparent when first driving it and watching knock counts. It was soo easy to do, I wish I would have done it earlier.
Now, a few things that I noticed:
1. If your fuel trims and scalings are right on with 93, you will have very little problems doing the switch.
2. Take your current scaling, using myself as an example, 1083, and reduce by 30% for a good start point. Mine was changed to roughly 750, and made my fuel trims almost exactly as they were with 93.
3. Fill up your tank with as minimal as possible 93 already in it.
4. Sit and let the car idle. I only reset the idle and had the A/C on to make the car consume the 93 in the rail a little faster.
5. Wait for the car to stumble and start running lean. (It's readily apparentwhen it hits the fuel rail/injectors)
6. Turn the car off and reflash for your 30% reduced scaling value. (I also at this time changed my idle values back to where they were before.)
7. Drive around and wait for your fuel trims to level out, and adjust your scaling as required. My latencies, as of 5:30 this morning don't seem to need to be touched at all, due to them being spot on with 93.
8. Start your normal tuning process for part throttle, and WOT.
It really was easy, I don't know why I was so nervous to do it. Now, I wish I would have done it before because I would probably have had better track times a few weeks ago!
Another note, when I started the car for the first "cold start" on E85, she fired up right away. I did change the Min Coolant Temp for Closed Loop to 20, but am going to go higher than that. (20 is only 68 degrees F) I am going to try 35 as that is 95 degrees F, which the car will never be after sitting all night. I also changed my fuel table values, 500-1000rpm 20-40 load from 14.7 to 11.0 to try and aid in cold start-up. The car fired up the first time. (I even have a startup data log of it.)
So a quick summary of all the things I changed to switch to E85 (In terms of ECUFlash)
1. My scaling, went from 1083 to 731 as it sits as of 5:30 this morning.
2. 500-1000rpm's 20-40 load from 14.7 to 11.0 (Don't think this is going to stay this way though)
3. Min Coolant Temp for Closed Loop from 7 to 20. (Going to raise to 35)
4. My exhaust smell. (He he..)
That's literally it. (Keep in mind, this was only to get the car to run and drive with say >20% throttle. You will need to do a full tune on the car to get the fueling correct at WOT, along with your timing tables as well.)
Old May 13, 2008 | 04:13 AM
  #40
erioshi's Avatar
Originally Posted by dude
Running the 9417008 rom with Tephra mods. Still have the annoying p0300 at 74mph and 26% throttle, hoping that switching over to 9417015 might alleviate that and allow me to finally unplug my darned Creader for once and all.
~ snip ~
All in all I'm pretty excited about it and want to give a big shoutout to Ted B for all his help. Hopefully we can post up after we get his monster Evo tuned on e85 as well...
I have been running e85 for over 6 months now with a tune based on the 9417008 rom & have been seeing P300 CELs at cruise. Recently I switched to the 9417014 rom & copied my tune over - again I was still seeing P300 CELs at cruise.
Recently I decided to try out some different strategies to tune out the P300 and see if I could tweak a couple of other issues like excessive RPM drop when approaching stops signs.
Originally I had my 1000 cc injectors scaled to 609 cc on e85 with the latencies tweaked to where everything looked good. After alot of experimenting with different injector sizing & latencies, I landed on a tune based on 680 cc injector sizing with custom latencies.
The result is most of my small driveability issues like P300 CELs and excessive RPM drop after throttle lift are completely gone. Even though new tune has the AFRs & LTFT values dialed to match my original tune, most of my minor issues have been resolved. My Creader is now history!
Based on my results I would have to guess that P300 CELs are being caused by fuel delivery settings. It might be interesting to see if a normal P300 car could be cured by rescaling the injector value and tweaking the latencies to match.
Eric
My car has seen temps anywhere from 70F (still spring) to -30F over the winter on e85 and I had no starting issues. For me the trick was to tweak the latency at voltages starting at 9v & below. With the right curve on the bottom end cold start is flawless.
Just thought I would share.
Old May 13, 2008 | 08:44 AM
  #41
l2r99gst's Avatar
Nice, that's what I was hoping for. How much did you have to increase your low end latencies by?
Eric
Old May 13, 2008 | 08:49 AM
  #42
mrfred's Avatar
Eric
I suspect that people are using latencies that are way off at the lower voltages. Hoping to add some clarity on latencies soon.
Old May 13, 2008 | 10:21 AM
  #43
tkklemann's Avatar
One of the things that I did with my latencies when changing to 1050's was to take the stock latences and graph them out in Excel. What you will see is that the latency values produce a nice gentle curve. When I tuned my 1050 latencies, I made another graphed line on that same graph to represent the new tuned latencies, and got the slope/shape of the line to mimick the stock curve, only at a higher level. It has worked great...
If you take my latencies and the stock latencies, graph them out, you will see exactly what I mean..
FWIW, here are mine:
3.912
2.304
1.512
1.152
0.816
0.6
0.456
Here are the stock values:
3.312
1.68
1.032
0.672
0.432
0.264
0.144
Take a minute, graph them out, and you will see what I mean.
Cold start at lunch today, she fired the first crank too... But, it's also low 70's out here too..
Old May 13, 2008 | 11:17 AM
  #44
l2r99gst's Avatar
My question was more along the lines of adding even more latency to the lower voltages to add much more fuel during cranking (if that actually is how it works).
When I say cold start, I mean below 0 cold starting, during the winter months.
The biggest complaint with E85 is the cold start issues (cold weather start) and I was wondering if simply bumping the lower voltage latencies even more would help that. According to erisohi, that is what he did and it worked great. I'm just curious how much he increased the lower voltage latencies.
Eric
Old May 13, 2008 | 11:40 AM
  #45
Jeff_Jeske's Avatar
It would be interesting to look inside the ECU of a flex fuel vehicle and see how it handles sub freezing cold starts.
