Evo Ix Ecu Pins Are Here!
Old May 23, 2008 | 04:03 AM
  #46
Jack_of_Trades's Avatar
Originally Posted by TouringBubble
3) The IX pins from JoT seem to be a little taller than the factory pins. Mine would not go in as far as the others. I finally checked the plug and realized that the pin was seated correctly even though about 1/16 of the top of the pin was still showing.
Thats interesting to know because these are supposed to be the exact same pins from the exact same manufacturer. I have NO Evo IX owners that live close to me so I never got to make any comparison in person, only from measurements via other owners on the forums.
4) Use the correct gauge wire for the ECU pin. I tried a 14 ga and it didn't want to work. I ended up going with a short piece of 18 ga I had left over from another project and connecting to the 14 ga I'd already run. It also helps if I ever need to disconnect it since I used a blade connector for this.
I suggest 22 gauge wire. Thats the best fit overall for these pins. Anything larger and you won't really be able to crimp over the insulation with the rear crimp tabs.
Old May 23, 2008 | 08:19 AM
  #47
TouringBubble's Avatar
Nearly the entire crimp tab in the rear is visible above the plug, whereas the stock pins sit about 3/64 in to the plug itself. It's almost like the rear tab shouldn't be there at all.
But, the pin sits correctly and makes a good connection. The lock also fits correctly over the pin.
It clips in correctly as well, but I actually broke mine (not sure if it was the pin or the plug) removing the pin the first time. Since it wasn't fully inserted as I'd expected, I tried to remove it and the wire slipped out of the pin. So, I used pliers to remove it and broke the latch. With the lock in place it doesn't move though.
The 18 ga I used worked out great. It is a little larger than the other wires but it fit the pin snugly and there were no clearance issues.
Old May 23, 2008 | 09:29 AM
  #48
Anyone else notice the same things on their IX's? I wish to god someone would buy a IX near me,lol. I hate relying on others to check stuff for me *control freak* lol.
Old May 23, 2008 | 10:23 AM
  #49
mrfred's Avatar
I can check this weekend if someone doesn't do it before then.
Old May 23, 2008 | 11:00 PM
  #50
al\lupo's Avatar
Jack, empty your PM box!
Anyway, I think they are mine...
Old May 24, 2008 | 06:54 AM
  #51
PM box cleaned out, and yours are taken care of now.
Old May 24, 2008 | 10:25 AM
  #52
mr2driver's Avatar
Harness ordered, thanks JoT!
Old May 25, 2008 | 03:49 PM
  #53
mrfred's Avatar
The pins are exactly the same as the pins that are used with the stock harness.
Old May 25, 2008 | 05:47 PM
  #54
Thanks for checking. Thought they were the same dimensions.
Old May 25, 2008 | 05:57 PM
  #55
Evoryder's Avatar
seeing this thread has me wanting to use my harness again...shame i could not get it to work.
Old May 25, 2008 | 06:24 PM
  #56
Send it back and I'll mail you a new one man.
Old Jun 6, 2008 | 02:35 PM
  #57
I forgot to make a post earlier this week but the last of the EVO IX pins were sent out to the people who pre-purchased an EVO VIII Alt-Map Harness from me. If you don't get any within the next few days, PM me. So far people have been safely getting them in the mail so I'd expect them VERY soon. Don't be alarmed if you get an envelope from Rhode Island with a small ziplock baggy taped inside. Bnice thought someone sent him some Anthrax or something,lol. I sent everyone a single pin with an inch of wire already installed, along with 2 uncrimped pins. Thanks guys!
Old Jun 6, 2008 | 07:00 PM
  #58
joedr's Avatar
EvoM Moderator
Thanks for the update JoT! Will be installing Meth... soon... very soon!
Old Jun 7, 2008 | 07:17 AM
  #59
mr2driver's Avatar
9 harness fit perfectly. Pin popped right in like it should. Thanks again.
Old Oct 25, 2008 | 10:58 PM
  #60
vtec2mivec's Avatar
Hey guys, considering making my own harness. Just have on quick question and don't really have time to read 1000+ post. Are the resistors getting hot at all? If so what did you use to keep them from burning holes in other wires? Thanks in advance.
