disable immobolizer
Old May 3, 2008 | 07:37 AM
Nevonate's Avatar
disable immobolizer
Gentlemen, I'm in a bit of a bind. I went out of state to get my alarm installed and forgot my spare key at home (both key's need to be present in order for the installer to setup the module that allows my remote start to work). Therefore I would like to disable my immobilizer. I am relatively new to EcuFlash. Currently, my Immobilizer code is "7501" and the init code is "0001".
I've been searching all morning and although this question has been asked before, I have not found complete answer. What do I change these to, in order to disable my immobilizer?
Thanks
Nate.
Old May 3, 2008 | 07:41 AM
sharkm87's Avatar
#ffff?
Old May 3, 2008 | 08:01 AM
EVOL03's Avatar
Have Them Do The Install And When You Get Home Put The Key In The Box Yourself . My Installer Would Not Install Mine I Had To Install The Remote Start Myself No Big Deal Took Me About A Half Hour But If He Installs Everything Then You Just Need To Put The Key In The Box Then Your Good To Go.....
Old May 3, 2008 | 08:09 AM
sharkm87's Avatar
thats true too, but atleast test it before you leave and put your primary key in there to see if it starts.
Old May 3, 2008 | 08:10 AM
Ryu123's Avatar
Add this to your ROM's XML file and change the value from 56DA to 56D2.
<table name="ECU Periphery0" category="Misc" address="faa" type="1D" level="1" scaling="Hex16"/>
Old May 3, 2008 | 09:36 AM
Nevonate's Avatar
Thanks! Exactly what I was looking for!
