FIC 1050 latency values?
Old May 3, 2008 | 07:40 AM
mrfred's Avatar
Are there published (from the injector manufacturer) values for FIC 1050 injectors?
Also, what latency values have people successfully used with FIC 1050 injectors?
Old May 3, 2008 | 01:50 PM
outbost's Avatar
Yes, if you know what they are please do tell. I have been playing around with mine this weekend because I can't get my car tunned untill I get these dialed in.
Old May 3, 2008 | 03:56 PM
grenade's Avatar
This is for FIC 1000cc/min injectors. I wanted to drive the car around and start it in sub freezing weather before posting up my values. Car starts up and idles fine in all weather conditions. This is for a DSM but the code is exactly the same on the evo and the values will transfer over. I do not use a stock O2 sensor though, my ecu talks to my LC1's wideband signal for closed loop cruising. So if anything my trims should be more accurate/consistent than a stock narrow band sensor.
4.69 4.371ms
7.03 2.427ms
9.38 1.467ms
11.72 1.155ms
14.06 0.963ms
16.40 0.867ms
18.68 0.771ms
For the global you have to do some math. My base fuel pressure is 56psi. Higher fuel pressure is not a linear relationship with respect to flow. Thus 56/43=1.3. Then you take the sqrt(1.3)=1.140 and multiply this by my rated flow of my 1000cc/min at 43psi to get 1140cc/min. I set my global to 1150cc/min. So for an evo at 43psi base you would take your stock global injector size and multiply it by x when [new inj size/number in ecuflash]=x. If you have higher than stock base fuel pressure you must do the math above.
In the end it is fairly plug and play with a little math and those latency numbers. Like I said my **** starts up and idles in 20 degree F weather with very large cams and large valves. It can sit and idle for half an hour on end, cruises well, and returns 30+ MPG. For the most part, it drives better than stock.
I know of someone running 1600cc/min injectors on the stock ecu but don't know their values, sorry. I just know its easily done
^ copy and paste from someone on evom.net
Old May 4, 2008 | 08:32 AM
outbost's Avatar
the FIC 1000cc and 1050cc are completely diffrent designs, just thought I'd throw that out there.
Old Jun 5, 2009 | 04:07 PM
redleg225's Avatar
Bump for this info. Anyone with input please post.
Old Jun 5, 2009 | 07:38 PM
RAbishi's Avatar
See this thread
https://www.evolutionm.net/forums/ec...-question.html
mrfred
Dec 27, 2016 09:26 PM
overdrive1
Dec 18, 2015 05:12 PM
Fuel Injector Clinic
Sep 17, 2014 09:25 AM
mrfred
Aug 17, 2010 07:00 AM
dan l
Sep 18, 2008 05:21 PM
