Please review my log
Old May 10, 2008 | 05:38 PM
rallykid's Avatar
Please review this log. 3rd gear pull. I can't seem to get rid off 1 and 2 Knocks. I would really like to swhoot for 0 knock.
File Type: zip
Old May 10, 2008 | 05:44 PM
4WS Tuning's Avatar
mod list? Just off hand i can say its too rich and not enough timing.....
Old May 10, 2008 | 06:55 PM
20Grockit's Avatar
^agreed. definately rich.
Old May 12, 2008 | 08:17 AM
rallykid's Avatar
Mods are:K&N cone, TBE w/ test, MBC.
Right so take the 10s and low11s to high 11s or low 12s for the A/F, correct?
How can I add more timing if I see 1 and 2 knocks (line 33 to 41) with timing at 4, 3 and 2?
Old May 12, 2008 | 02:28 PM
G20's Avatar
G20
make your timings gradually stepping up starting from 2-3 timings around 3000 rpm. Your timing map from the begin can affect the knock sums as well. Your AF is also on the rich side like 4WS Tuning mention. Usually high 11s or low 12s when starting to boost, 11.1-11.4 at peak and try to maintain it from there. I prefered a little richer up top starting from around 7200 rpms.
My 05 MR has similar mods like you except K&N drop-in instead of cone.
Old May 12, 2008 | 03:00 PM
Mr. Evo IX's Avatar
Not enough timing midrange. Fuel map needs some work too.
Old May 13, 2008 | 10:37 AM
4WS Tuning's Avatar
set the boost to 21-23 pounds est... Still dont know your mods..
Shoot for a solid 11.5-11.6 afr
The add timing until youre not making enough power to benefit the addition timing..
Thats tuning in 3 steps....
Old May 13, 2008 | 10:55 AM
rallykid's Avatar
thanks for the feedback guys, appreciate it. I will redo the map, and post new log when done.
Old May 13, 2008 | 02:16 PM
bnice01's Avatar
timing should progress with engine speed ie 2,3,4,6 not 3,2,2,4,3, a good number to start with is right around peak boost (22psi) set timing to 2-3* and progress to around 11-12* @ redline. that should get you going for now.
Old May 13, 2008 | 02:50 PM
Mr. Evo IX's Avatar
Can someone please sticky this post.
jakgal04
Mar 28, 2016 08:16 AM
acamus
Oct 24, 2008 06:22 AM
Dapper Dan
Aug 29, 2006 11:21 AM
Girlie
Jul 11, 2006 08:36 AM
racegate
AEM EMS
Jul 17, 2005 01:35 PM
