EcuFlash and Vista
Old May 17, 2008 | 12:20 PM
markymark1082's Avatar
EcuFlash and Vista
Has anyone had problems reading the ECU with EcuFlash using Windows Vista?
Old May 17, 2008 | 12:24 PM
alan678's Avatar
Not me.....I have used ver 1.29, 1.34 and now the new 1.35 with no issues what so ever....have had the laptop since July 07...
What error code are you getting?
Old May 17, 2008 | 12:32 PM
It says "An unknown error occured. See Log for details." Here is the log:
[15:30:51.918] Using interface OpenPort 1.3 Universal TX26apCv972db7c99d10f094ed94cac81eb2c9401a7d7459
[15:31:00.822] sending init sequence 1 (0001)
[15:31:04.089] sending init sequence 1 (0003)
[15:31:07.345] sending init sequence 1 (FFFF)
[15:31:10.089] no response to any known code
[15:31:10.091] interface close
[15:31:10.107] interface close
Old May 17, 2008 | 03:30 PM
SLO-EVO's Avatar
redownload the ecu flash... i had to download it bout 4x until i got all of the files downloaded... i dont know... then i had to fish for a dll file that was missing..
Old May 17, 2008 | 04:50 PM
Thanks. I'll try that.
Old May 17, 2008 | 05:49 PM
oldevodude's Avatar
You can get that error when the tactrix open port driver is not recognized on the correct port. Go to device manager and check the port then match it in the software.
I also installed mine in a different directory than normal and it seems to work better.
c:\ecuflash in stead of c:\program files\openecu\ecuflash.......
Vista has some write protection on files located inside of the prog. files directory.
Uninstall reboot then re-install could fix as well.
Old May 17, 2008 | 07:06 PM
So I uninstalled EcuFlash and reinstalled it. I now have another problem. When I try to read from the ECU, EcuFlash pops up with the window to select your vehicle, like normal. I select mine, click read and the program does not respond and freezes up. So I have to close the program and try it again. Same thing happens. I tried uninstalling and reinstalling, numerous times, in a different location and the same thing happens. Even after uninstalling and reinstalling, the date modiefied is the same as when I first downloaded the software. I can't figure it out. Can anyone help?
Old May 17, 2008 | 08:40 PM
Old May 18, 2008 | 04:14 AM
Mattjin's Avatar
I get the same problem. After selecting the vehicle type it hangs.
It did not happen with V1.34, only started happening with V1.35. Removed it and re-installed V1.34 and it works fine again.
Old May 18, 2008 | 06:20 AM
I downloaded v1.34 and am encountering the same error code that I was getting before.
Old May 18, 2008 | 12:55 PM
I bought the Tactrix cable off of another user on here. Do you think he could have sold me a bad cable?
Old May 18, 2008 | 01:00 PM
Jeff_Jeske's Avatar
Try this....
Start the car .... then attempt to connect.
Old May 18, 2008 | 01:35 PM
Originally Posted by Jeff_Jeske
Try this....
Ok, just tried that. EcuFlash shut the car off and gave me the same error.
Old May 18, 2008 | 01:54 PM
oldevodude's Avatar
Have you ever had the cable working? Maybe try a known good cable for comparison. Something doesn't sound right. Shutting off the car? That is strange
Old May 18, 2008 | 02:14 PM
Jeff_Jeske's Avatar
Shutting the car off is what is supposed to happen. So his cable is functioning correctly. I'm guessing its an openecu config issue.
