Using Boost Control patches with V5 Patch
Old May 19, 2008 | 08:25 PM
turboracer's Avatar
OK, read all of the manuals for these and V5. It is unclear whether it is safe to fiddle with these when used together.
Would there be any problems with using this and the V5 rom together for more refined boost control? How would these parameters affect boost control in alt map mode?
https://www.evolutionm.net/forums/sh...d.php?t=288408
Also how about these parameters?
https://www.evolutionm.net/forums/sh...d.php?t=333479
Are they safe to fiddle with as well?
Thanks
Old May 19, 2008 | 09:16 PM
tephra's Avatar
mrfreds patches right?
you should be good to use them, basically all you are doing is changing the scaling of the tables...
I use directboost with V5 so its all good
RazorLab's Avatar
Both work perfectly fine with v5.
