Review/Advice Before Tuning (log attached)
Old May 28, 2008 | 05:20 PM
acct918's Avatar
Here is a log of my car and any advice and/or review of it is greatly appreciated.
I run 91oct and mods are TBE, injen intake with ams lower IC and the injen UIC.
After looking at other logs, my load seems low. Maybe that is just my car? Only hits around 230-240 or so and are the fuel trims suppose to be at 11 and 8?
I am planning on tuning for 3-4 timing and gradually to 10-11 at redline. The timing looks like crap right now.
Any info would be great thanks a lot.
PS: I know I don't have a wideband.
Log is attached.
File Type: zip
Old May 28, 2008 | 11:21 PM
nonschlont's Avatar
ok my .02 first if you still have the stock injectors, you shouldnt need to worry about fuel trims. Second, you should be logging tps/rpm/wgdc/boost (if u have a jdm/evo x map sensor) / knock/ timing/ WGDCC and load error. It helps to have it in order like this, so your not moving the screen left and right. You should be using "2byteload" to log load! There are many formula changes needed to be made in Evoscan to log correct data. All the info u need reguarding this is in the sticky section of the ecuflash forum.
