evoscan question
Old Jun 7, 2008 | 09:22 PM
EVOllie's Avatar
evoscan question
can you check and clear engine codes with evoscan?
Old Jun 7, 2008 | 09:34 PM
tnt1106's Avatar
yes you can
Old Jun 7, 2008 | 09:48 PM
EVOllie's Avatar
Thanks for the reply.
Another question for you or anyone else,
Under evoscan usb cable. Do i click obd-II or mitsubishi
Also under select ecu, do i keep that at efi?
Thanks guys, i just downloaded it a little while ago, and im sittin here charging my lap top lookin at it.
Old Jun 8, 2008 | 08:52 AM
sponners's Avatar
click on mitsubishi and efi
Old Jun 8, 2008 | 09:01 AM
Psquared's Avatar
how exactly do you go about that?
Old Jun 8, 2008 | 09:06 AM
EVOllie's Avatar
ok thanks, thats what i have it at.
Im having trouble looking at the codes. my check engine light is on, but when i click DTC, it says evo4 no codes (or something like that) and if i click clear DTC, an error comes up and says it can only clear pre 1997 mitsubishis , do you wish to clear, yes or no.
This doesnt seem like a complicated program. What am i doing wrong?
Old Jun 8, 2008 | 09:21 AM
Mr. Evo IX's Avatar
EvoScan doesnt clear codes, at least not yet that I'm aware of.
There is a program called scantech that will let you view your codes, freeze frame data, clear codes, with the tactrix cable. It's on aktivematrix and you have to register for downloads.
http://www.aktivematrix.com/forum/dl...ile&file_id=27
Old Jun 8, 2008 | 09:24 AM
Kracka's Avatar
I can clear my codes with EvoScan (or at least it turns off my check engine light).
Old Jun 8, 2008 | 09:32 AM
EVOllie's Avatar
can u see them before you clear them?
like i said, it did give me an option to clear codes anyway, but thats not what i want really, i wanted to see what code.
Old Jun 8, 2008 | 09:38 AM
Kracka's Avatar
I can see them, but I don't think it reads the code right b/c the code shown is wrong.
Old Jun 8, 2008 | 09:54 AM
EVOllie's Avatar
can u tell me what ur doing to get the code? i have mine on mitsubishi and efi, i click DTC and in the lower right corner in the white box it says something about no codes and evo4?
Old Jun 8, 2008 | 10:45 AM
merkzu's Avatar
It doesnt show the code ID for me and it gives the wrong code description.. you are better off using scantech, it's free and works with the tactrix cable
Old Jun 8, 2008 | 10:48 AM
fostytou's Avatar
EvoM Community Team
The newer version (2.3Beta2) can read and clear codes up to evo IX (and also has AYC/ABS code reading/actuation if your cable supports it)
Its nice, you can even see DTCs that have turned off but not been cleared yet
I thought 2.2 full could also do it
Old Jun 8, 2008 | 10:50 AM
EVOllie's Avatar
thanks guys
Old Jun 8, 2008 | 10:55 AM
Mr. Evo IX's Avatar
I didnt know that it could clear codes now. Thanks for the info.
