Patch Idea-gear dependent boost
Old Jun 8, 2008 | 02:12 PM
Mr. Evo IX's Avatar
Since the factory boost system has so many duty tables could a patch/hook be put in when the solenoid activation rpm is met, it checks the vehicle speed sensor to determnie which table should be looked up for duty cycle?
Old Jun 8, 2008 | 06:34 PM
tephra's Avatar
yeah I wsa going to implement something like this a while ago.
just as simple as if its in 1/2/3 then do one WGDC table otherwise if its 4/5/6 then do another...
Old Jun 8, 2008 | 06:46 PM
chmodlf's Avatar
The much maligned lean spool takes into account gear when calcuclating AFR. Not boost but...
Lean spool is supposed to have richer AFR for higher gears and leaner for lower gears.
Old Jun 8, 2008 | 06:51 PM
chmodlf's Avatar
duplicate post sorry
Old Jun 9, 2008 | 07:37 AM
TouringBubble's Avatar
I like this idea. It's not a big issue for me really using direct boost control and keeping the + error correction, but the WGDC needed for set boost varies greatly between gears. Ideally, I'd say 1&2, 3&4, 5&6 could use their own WGDC tables, but 123 and 456 would work as well.
I'd like to think that letting 5&6 share their own boost tables could help save fuel as well for highway cruising/passing ...
Old Jun 9, 2008 | 09:00 AM
mplspilot's Avatar
It's been discussed before. Bez probably has it on his car
https://www.evolutionm.net/forums/sh...d.php?t=296503
Old Jun 9, 2008 | 09:43 AM
honki24's Avatar
nice.... so how do we gets a hold of it? 941780015
